Toymods » Tech & Conversions » 4agze SC noises
djb23_20v
Wollongong
4agze SC noises Sun, 07 July 2002 13:06 Go to next message
Hi guys,
When I rev up my just installed 4agze, the supercharger rattles quite loudly as the sc clutch engages. You can just hear it from inside the cabin when driving. I checked that it was the sc by disconnecting the sc relay and giving it a rev.
I've verified that the sc has oil in its sump, so I'm wondering if this noise is something to do with the sc being unused for some period of time and the gears/bearings being dry.
Has anyone experienced this before?
feral4mr2
Bundaberg, Qld.
icon7.gif  Re: 4agze SC noises Mon, 08 July 2002 10:39 Go to previous messageGo to next message
Freak yeah, the one i have on at the moment does it just of idle, it has a fixed 90mm pulley on it. i'm lending it from a friend to see how it goes, so i wont pull it apart to have a look. it had been sitting a while to, so you could be right about the bearings?? anyway it comes off tomorrow, so i can start on my turbo conversion. btw, 160mm crank pulley, 90mm fixed s/c pulley, 12psi very nice! Grin
Jonoze
Re: 4agze SC noises Mon, 15 July 2002 00:22 Go to previous messageGo to next message
I had that problem when i first got my motor. Some monkey in Japan had left the nut which secures the s/c clutch mechanism loose allowing the inner part of the clutch to wobble/rattle around. When i removed mine to look the clutch surface was stuffed with deep gouges all over it. I then had to source a new s/c clutch which wasnt fun at he time.
AE82TwinCam
Canberra, ACT
Re: 4agze SC noises Mon, 15 July 2002 04:08 Go to previous messageGo to next message
On an SC12 related topic, when I rev my 4agze quite high like towards 6500 and over it starts to make this little screeching sound, could it be belt slip or something? it doesn't happen at all at lower revs no matter how much or how little boost so I don't know.. The SC has oil in it, and I've been driving it for around 4 months now, I don't remember it happening when I first had it in the car...
any suggestions?
-Andrew
Jonoze
Re: 4agze SC noises Mon, 15 July 2002 04:17 Go to previous messageGo to next message
Sounds a bit like belt slip to me. Tighten your belt up a bit and take it for a run. Hopefully the noise will be gone!
feral4mr2
Bundaberg, Qld.
icon7.gif  Re: 4agze SC noises Mon, 15 July 2002 06:21 Go to previous messageGo to next message
Freak yes, classic s/c symtom, belt slip. Sad
AE82TwinCam
Canberra, ACT
Re: 4agze SC noises Mon, 15 July 2002 12:18 Go to previous messageGo to next message
Probably simple question but...
what do I need to do to tigten up the belt?
-Andrew
Ben Wilson
Re: 4agze SC noises Tue, 16 July 2002 01:45 Go to previous messageGo to next message
http://www.mr2sc.com/websites/tech/adjusting_a_squ ealing_supercharg.htm
That should get you going...
AE82TwinCam
Canberra, ACT
icon10.gif  Re: 4agze SC noises Tue, 16 July 2002 03:00 Go to previous messageGo to next message
sweet, thanks Ben.
-Andrew
Allan
Re: 4agze SC noises Tue, 16 July 2002 04:58 Go to previous message
anyone managed to fit a double V belt drive from an AC compressor to one?
Allan
Previous Topic:performance from 1g-gte conversions?
Next Topic:MA61 diff ratios
Current Time: Mon Oct 19 17:44:08 UTC 2026
Total time taken to generate the page: 0.072476148605347 seconds
