Toymods » Tech & Conversions » Air/Fuel ratio
Ribbo
Northern Beaches
Air/Fuel ratio Sun, 07 July 2002 13:39 Go to next message
ok got dyno sheet and was checking out the air/fuel ratio and wondering what the best is?
its a 4age with microtech digi 1
its been tuned and is very flat ratio all the way through the revs of slightly above and under 12.5
is this what it should be?
what gives more power, leaner or richer?
thanx
[Updated on: Sun, 07 July 2002 13:40]
Rex_Kelway
Re: Air/Fuel ratio Sun, 07 July 2002 13:51 Go to previous messageGo to next message
About 12.3 is the best for making power on petrol or atleast where most cars make their best power.
However, 14.7 is the ratio at which stoichmetric (petroleum) mixtures occur which results chemically in prefect combustion and hence far lower emissions.
MRTA22
Re: Air/Fuel ratio Mon, 08 July 2002 01:03 Go to previous messageGo to next message
If the car is running alright at that ratio it will be fine. If it blows slight fuel smoke it may need to be leaned off. Also check your plugs for fouling, you may need a different heat range if they are.
Jamie.
Ribbo
Northern Beaches
Re: Air/Fuel ratio Mon, 08 July 2002 08:33 Go to previous messageGo to next message
ill have to get someone to look when they are behind me..... Bigworm seems like a good contender as he sees my rear lights often Laughing j/k joel
BigWorm
Toymods Board Member
Turramurra, Sydney.
Re: Air/Fuel ratio Mon, 08 July 2002 08:50 Go to previous messageGo to next message
Twisted Evil Twisted Evil Twisted Evil Twisted Evil Twisted Evil Twisted Evil Twisted Evil Twisted Evil Twisted Evil Twisted Evil Twisted Evil Twisted Evil Twisted Evil Twisted Evil Twisted Evil Twisted Evil Twisted Evil Twisted Evil Twisted Evil Twisted Evil Twisted Evil Twisted Evil Twisted Evil Twisted Evil Twisted Evil Twisted Evil Twisted Evil Twisted Evil Twisted Evil Twisted Evil
Haha, very funny!
I wouldn't worry too much, from what I remember from looking at your printout, the hitmans done a pretty bloody good job.
MRTA22
Re: Air/Fuel ratio Mon, 08 July 2002 09:02 Go to previous messageGo to next message
If the hitman tuned it i wouldnt be worrying. from what ive heard he is one of the best. Joel you can have the Celica getting beaten, go to work and save for a turbo conversion.j/k
Jamie.
SUPRAGTE
North Sydney
Re: Air/Fuel ratio Mon, 08 July 2002 09:03 Go to previous messageGo to next message
Your pretty lucky will af ratios that good.
Digi's are the older type microtech with pots for fuel adjusment arn't they?
If so that's really good, the guy who tuned it done it well.
Apparently from what i've heard anywhere between 12.4 to 12.6 is good for solid power provided your engine isn't prone to detonation which the 4AGE isn't.
At the dyno day it was perfect to see such a wide variety of cars and watch their af ratios as they get stuck into it. I couldn't leave the dyno room cause i was so interested in seeing what cars were running what.
Last year i remember a turbo mirage running ratios above about 19:1!
Yesterday i saw the LS1 Gen 3 running into the 10's cause holden chip them way safe.
TA22-3SGTE
MACKAY
Re: Air/Fuel ratio Mon, 08 July 2002 12:35 Go to previous message
13.2 AFR will produce maximum power, So it is normal to run the mixtures around 12.5 to be on the safe side .
Trevor
Previous Topic:Rotaries in Celicas?
Next Topic:Detonation Problem
Current Time: Mon Oct 26 05:04:16 UTC 2026
Total time taken to generate the page: 0.0060532093048096 seconds
