Toymods » Tech & Conversions » celica gt4
i2obert
celica gt4 Mon, 04 August 2003 21:44 Go to next message
how hard is it to get some good preformance out of these gt4s pop up light version ???? lets say 13s
MR. 2
Parramatta
Re: celica gt4 Mon, 04 August 2003 23:43 Go to previous messageGo to next message
easy just cost money! like anything!!
rebuild with head work and then high flow turbo lots of boost and computer low 13s im sure!
crazy_camry
Re: celica gt4 Wed, 06 August 2003 07:15 Go to previous messageGo to next message
i read in old Hot 4's that GT4 gearing in ST185 was not good for 1/4 mile and only managed 15's but the guy swapped out to a ST205 gearbox and diffs and took a second off.
wiso
Re: celica gt4 Wed, 06 August 2003 07:33 Go to previous messageGo to next message
if you go to see this thread
http://forums.toymods.org.au/index.php?t=msg&t h=17337&start=0&rid=2471&S=5d5a660311d e8858b974cc9991c50424
at the bottom you can download the hot4s article just rad through my posts
Necros
Re: celica gt4 Wed, 06 August 2003 09:17 Go to previous messageGo to next message
Heh hot4s ;p Dont their stickers make your car go faster?
Well the reason st185's are doing quater miles in the 15 second bracket is because boost is limited to 6psi in 1st and 2nd...
And there isnt anything wrong with the gearing ;p My grp a gt4 was in doing mid/high 13's with very little work. 3 1/2" Downpipe + std exhaust, K&N Filter, No boost limits in 1st and 2nd... Boost was at about 10psi. Oh and the grp a's have a 3.9 final gear as opposed to a 4.1 in the std models.
If you want your gt4 to go faster then do the usual ;p 3" Zorst, 13-14psi boost w/ high flowed turbo, cold air setup and a front mount ic would helpa lot too... 13's would be easy as...
Classique71
Colac, Victoria
Re: celica gt4 Wed, 06 August 2003 09:48 Go to previous messageGo to next message
necros is right on the money - And a decent launch helps ALOT - a few more PSI of boost - aftermarket ECU - and some good tyres on that - would see it into the mid/high 12's
the 205 GB makes the car defiantly zippier - over the box mine has - though for top speed - the long gears of the standard 185 Gt4 would see it outpacing the others in the end ! ( i think )
also removing some of the piggyness of the 185 helps - Start with the front bumper - - swap that to the grp A spec bumper - and the alum mounting bar instead of the chunky plastic standard one and steel mounting bar andyoull see it shed a few pounds over the nose ..
crazy_camry
Re: celica gt4 Thu, 07 August 2003 00:22 Go to previous message
[quote title=Necros wrote on Wed, 06 August 2003 19:17]Heh hot4s ;p Dont their stickers make your car go faster?[quote]
yeah i don't buy that magazine anymore, seem to have gone away from doing technical and diy articles
[Updated on: Thu, 07 August 2003 00:23]
Previous Topic:1JZ-GTE , looking for a FCD
Next Topic:4age 16v FWD convert to RWD
Current Time: Sat Nov 21 06:24:23 UTC 2026
Total time taken to generate the page: 0.0053069591522217 seconds
