Classifieds » Miscellaneous » APEXI SAFC II FS
KOFFEE-BLACK
APEXI SAFC II FS Wed, 06 August 2003 05:23 Go to next message
Hey guys, I bought the SAFC II about 2 months ago, but wont need fo the Turbo install, as im getting a Haltech E11.
The RRP is $770, but give me an offer I cant refuse!!
NOTE: ITS BRAND NEW!! Here are some specs and a picture
A'PEXi S-AFC II
SUPER AIRFLOW CONVERTER
The new generation S-AFC II features following functions.
At MONITORING MODE
*Knocking level display enables you to check if any detonation happening on the engine. This function is very useful to do ECU setting as well as to check engine condition.
*The unit can show 4 different information on its screen. You can select from Airflow signal, Intake Manifold Pressure, Throttle position signal, Engine rpm, Airflow signal offset %, Engine knocking level and Battery voltage.
*Display pattern can be selected from one of normal, analogue, digital analyzer or graphic.
*Each information on the screen can be played as real time, peak hold, replay or pause.
At SETTING, etc MODE
*You can adjust fuel setting at the range from -50% to +50% (every 1% unit) at 12 different engine rpm you set.
*The unit allows you to set two fuel setting patterns for wide throttle opening situation and narrow throttle opening situation.
*Engine anti-stall adjustment solves the engine stalling problem that is caused by blow off valves, etc...
*Warning function prevents your car from having engine trouble.
*Security function allows you to set pass word so the setting data cannot be changed accidentally.
*Even if the battery is disconnected, the unit keeps all the data in its memory.
*By-pass function allows airflow signal to by-pass S-AFC II, so you can use standard airflow signal temporarily.
http://www.perfectrun.com.au/real_size_image/electronic_controller/air_flow_controller&analyzer&fuel_controller/ApexiS-AFCII.jpg
KOFFEE-BLACK
Re: APEXI SAFC II FS Wed, 06 August 2003 05:26 Go to previous messageGo to next message
email me here shane.standley@thomson.com.au
KOFFEE-BLACK
Re: APEXI SAFC II FS Wed, 06 August 2003 23:16 Go to previous messageGo to next message
Sold guys.
KOFFEE-BLACK
Re: APEXI SAFC II FS Fri, 08 August 2003 00:38 Go to previous message
Buyer backed out guys, still for sale, give me your best offer!!
Previous Topic:17inch ACB Chromies
Next Topic:ta22 junk
Current Time: Thu Oct 22 06:54:55 UTC 2026
Total time taken to generate the page: 0.0041251182556152 seconds
