Classifieds » Parts Wanted » 3TGTE
TRD78
3TGTE Wed, 06 August 2003 11:44 Go to next message
anyone happen to have a 3TGTE lying around? Or know of one someone else may have? as close to complete as possible preferably, but if not let me know anyway... need one for my TA22 ASAP... will be rebuilt anyway...
juzzo84
Hornsby, N.S.W
Re: 3TGTE Wed, 06 August 2003 21:36 Go to previous messageGo to next message
man i have a complete 3tgteu lying around, its just that its in 3 bits, the efi,head and bottom end
justin
TRD78
Re: 3TGTE Fri, 08 August 2003 21:46 Go to previous messageGo to next message
*bump*
TRD78
Re: 3TGTE Sun, 10 August 2003 09:40 Go to previous messageGo to next message
nevermind ppl...i've bought one Very Happy if anyone has a ECU or AFM i will be interested tho...
Jaxe
Re: 3TGTE Sun, 10 August 2003 23:15 Go to previous messageGo to next message
Hey TRD78, where did you get one from and how much etc?? I've been thinking about dropping one into my ST162 for some time now.
Cheers.
TRD78
Re: 3TGTE Fri, 15 August 2003 10:24 Go to previous messageGo to next message
Ok ppl, now i'm after an ECU, preferably off a 3TGTE, or off a 2S from a camry... Also injectors and other stuff i will post as i remember...
i think u r probly refering to a 3SGTE, Jaxe, as it would be pointless going backwards in a car that a 3S bolts straight into...
TRD78
Re: 3TGTE Fri, 15 August 2003 10:30 Go to previous messageGo to next message
OIL COOLER! i need an oil cooler too!
Snyper
Re: 3TGTE Fri, 15 August 2003 22:46 Go to previous messageGo to next message
do you need a turbo and manifold ?!
Brendon
TRD78
Re: 3TGTE Fri, 15 August 2003 22:52 Go to previous messageGo to next message
NO, no my turbo is fine, here is a list of all the things i need...
*ECU
*Injectors
*Fuel Pump
*Bigger brakes
*Bigger fuel lines
& oil cooler...
Troy
TRD78
Re: 3TGTE Fri, 22 August 2003 10:37 Go to previous messageGo to next message
I have an oil cooler now am still after computer and Injectors, these are my main concerns... anyone? hello?
CLG
Perth, Western Australia
Re: 3TGTE Fri, 22 August 2003 13:45 Go to previous messageGo to next message
oops, sorry read the next one!
[Updated on: Fri, 22 August 2003 13:49]
CLG
Re: 3TGTE Fri, 22 August 2003 13:47 Go to previous messageGo to next message
I have a dozen spare injectors, unfortunately I think they're all stuffed. They may come back with a clean, but my gut feeling is they would need alot of time and need to be "heated" to dislodge impurities in them. They have been tested and do spray, but the patterns are all over the place, hence my reluctance to spend any money on them. You can have the lot for $30 if you can't find any others, if you get four good ones - half your luck!
I also have a spare 3TGTE oil cooler, if you want a factory item? Be careful when bolting these up, there are differences that need to be addressed between water and oil cooled turbos. Let me know if you want any help in that area?!
CLG
Re: 3TGTE Sat, 23 August 2003 12:59 Go to previous messageGo to next message
TRD, got your PM, thought it'd be better to post the info here on 3TGTE's so others can read it as well!
3TGTE's come with either an oil cooled or water cooled turbo. Oil cooled turbo motors come with an oil cooler factory fitted, however it is only operational when the oil heats up - ie they have a thermostat that controls oil flow to the cooler. There is no oil flow to the cooler until the oil reaches an increased temperature.
If you have a factory oil cooled turbo motor, you can simply install the oil cooler without having to worry about the thermostat. While the oil is cool, it will bypass the cooler and head straight to the turbo via the steal main oil supply line that exits from the alloy fitting before the oil filter. Once the oil heats up, it runs through the cooler and then into the turbo via an alternate route.
If your motor was originally a factory water cooled turbo that you want to install a factory oil cooler onto, you need to install the thermostat in the end of the steel main oil supply line that exits from the alloy fitting before the oil filter.
If you want to convert an oil cooled turbo motor to a water cooled turbo unit, you will need to remove the thermostat from the line. Failure to do this will see you starve the turbo of oil once the oil heats up, as the thermostat restricts oil flow through the main oil feed line.
The oil cooler I have is a factory unit with the correct length lines too, you can find a picture of it in my ad titled "Performance Goodies For Sale" in the car parts for sale section, will PM you some details on those injectors and oil cooler!
TRD78
Re: 3TGTE Fri, 29 August 2003 09:58 Go to previous messageGo to next message
Yeh mine is just standard oil-cooled turbo version, it has all that thermostat and stuff, will probably get braided lines and stuff, just need the actual cooler... do u have any idea where they were mounted on carina's or whatever from the factory? I'm trying to decide the best place...
Troy
CLG
Re: 3TGTE Fri, 29 August 2003 13:37 Go to previous message
They were mounted on the LHSide of the vehicle in front of the Water radiator.
Previous Topic:TA22 parts, Bellhousing
Next Topic:ta22 Seats need em
Current Time: Thu Oct 15 10:42:31 UTC 2026
Total time taken to generate the page: 0.014079809188843 seconds
