Toymods » Tech & Conversions » doesw anyones fuel/temp guage needles jump about?
munki
Gold Coast
doesw anyones fuel/temp guage needles jump about? Thu, 07 August 2003 01:10 Go to next message
hi all
its really starting to annoy me when i go over a bump because my fuel/temp (mainly fuel) will jump alover the place. is there any fix for this? oh and its in a RA23
Daniel
Stenno
Re: doesw anyones fuel/temp guage needles jump about? Thu, 07 August 2003 02:06 Go to previous messageGo to next message
It sounds like you may have a loose earth strap, check all the earth points that go to and from your gauges.
munki
Gold Coast
Re: doesw anyones fuel/temp guage needles jump about? Thu, 07 August 2003 09:17 Go to previous messageGo to next message
that seems unusual, can you explain how these guages work? your saying that a weak signal will make the needle wobble arround on rough roads.
i is stupid.
gabe
Re: doesw anyones fuel/temp guage needles jump about? Thu, 07 August 2003 09:40 Go to previous message
These are moving coil guages. Basically an ammeter. A variable resistor changes the current draw in the circuit. The variable resistor in this case is the fuel sender.
The fuel guage basically measures current(the guage is not calibrated in amps though)
The cause for the jumping around is basically sloppage in the guage linkages etc.
not sure if there is an easy fix for this problem
Previous Topic:SR20 Engine number location
Next Topic:cams cams cams
Current Time: Sat Nov 21 06:46:05 UTC 2026
Total time taken to generate the page: 0.0040547847747803 seconds
