Toymods » Tech & Conversions » BACKFIRE!
bass_boy
BACKFIRE! Thu, 07 August 2003 03:00 Go to next message
hi guys.. i am now the proud owner of an ae92 sx with a 20v blactop... my question is about the exhaust.. why, on high rpm changes, does the car backfire. its not a major BANG type backfire, more of a crackle which happens a few times in a second.
what is causing this? how can i fix it?
thanks!
Re: BACKFIRE! Thu, 07 August 2003 05:44 Go to previous messageGo to next message
does it have an a/m exhaust?
lots of cars with big exhausts crackle and pop on gear change
(dont know why tho)
bass_boy
Re: BACKFIRE! Thu, 07 August 2003 08:27 Go to previous messageGo to next message
yeh.. 2.5 inch i think...
u think i need to go down to 2.25" to stop it?
Re: BACKFIRE! Thu, 07 August 2003 08:33 Go to previous messageGo to next message
usually from pulling air/fuel thru the chamber and igniting in the exhaust. is it running rich? do you have a cat? (excess fuel and cat=bad), stock or aftermarket ECU?
sound slike it needs a bit more decel fuel cut.
bass_boy
Re: BACKFIRE! Thu, 07 August 2003 15:05 Go to previous messageGo to next message
yes 2 cat... and no to aftermarket ecu
what r my options?
boudan
Re: BACKFIRE! Fri, 08 August 2003 01:48 Go to previous messageGo to next message
2.5 inch pipe seems excessive, you'd be losing quite alot of of your low band power, and as it reaches high band the large pipe diametre cause a baffle, the crackle which you here...
2.5inch without known tip diameter + 2x Cats would significantly root exhaust flow...
Most likely also has an improved air filter or not ?
As for your solution, try having your A/F tuned to the correct mixture considering any aftermarkets parts. If you wanted to solve the problem permanetly have a 2 1/4 or 2 inch pipe fitted unless you plan to majorly increase your power levels.
bass_boy
Re: BACKFIRE! Fri, 08 August 2003 08:29 Go to previous messageGo to next message
yeh i thort 2.5" was a little large. i am gettin another resonator put on on wed so i will speak to te "experts" about it then..
-Mark-
Re: BACKFIRE! Fri, 08 August 2003 18:00 Go to previous messageGo to next message
Why is this a problem?
I get foot long flames out of the trueno when off throttle at high RPM.
Wouldn't have it any other way Smile
bass_boy
Re: BACKFIRE! Sat, 09 August 2003 03:29 Go to previous messageGo to next message
its a prob coe of the MAJOR flat spot i have between 2800 and 3300rpm... also i dun really wanna attract the police attention any more than it already does..
manipulate
Re: BACKFIRE! Sat, 09 August 2003 03:32 Go to previous messageGo to next message
yeah its not backfire
as Draven said most cars with a/m exhausts crackle a bit when letting off the gas
it doesnt matter at all
i think its got something to do with pressure changing in the exhaust
and yes 2.5 is too big for a GE
Ta
Mani
Re: BACKFIRE! Sat, 09 August 2003 06:30 Go to previous message
If you've got a serious flat spot, then it's probably due to another issue, that is also causing the backfiring. Maybe your air flow meter is crook?
Previous Topic:Supra won't fire - need help !
Next Topic:wrird knocking/ticking noise
Current Time: Sun Nov 1 05:45:44 UTC 2026
Total time taken to generate the page: 0.0051629543304443 seconds
