Toymods » Tech & Conversions » which brake master cylinder?
Chris Davey
sunny coast, qld
which brake master cylinder? Thu, 07 August 2003 11:45 Go to next message
In my Corona I have HQ holden front brakes with large single piston caliper and imported Pajero rear brakes (i think). This is substantially larger than the small single piston front and drum rear that was standard. I have metric brake lines also. Does anyone know what sort of master cylinder i should look for that will be able to push enough fluid to my brakes?
thanks in advance
Re: which brake master cylinder? Thu, 07 August 2003 12:43 Go to previous messageGo to next message
Your best bet is to measure the piston diameter of your calipers, and use a master cylinder from a car with the same size caliper pistons.
Chris Davey
sunny coast, qld
Re: which brake master cylinder? Fri, 08 August 2003 01:16 Go to previous messageGo to next message
I AM 90% certain that all pistons are 60mm diameter. 2 pairs of signle pot calipers. that help?
Re: which brake master cylinder? Fri, 08 August 2003 01:58 Go to previous messageGo to next message
You said they're HQ brakes right? Can you find out the bore diameter of a HQ master cylinder?
Chris Davey
sunny coast, qld
Re: which brake master cylinder? Fri, 08 August 2003 03:38 Go to previous message
yeah HQ on the front and pajero on the back. I will see if i can find the bore diameter of the HQ ones. But would a HG have rear disks as well?
Previous Topic:Pod vs panel filters
Next Topic:best computer for 20V?
Current Time: Sat Oct 31 11:43:32 UTC 2026
Total time taken to generate the page: 0.041000843048096 seconds
