Toymods » Tech & Conversions » Thermofan question
Simon-AE86
Banned user
ADELAIDE - The Drift City
Thermofan question Thu, 07 August 2003 22:59 Go to next message
old thermo fan switch died.. so i bought a new repco one.. i wire it up and the fan is either full on all the time regardless of temp or not on at all.
now.. heres the situation, The old set up was a temp switch with three terminals, only two wires hooked up, the temp probe going into the radiator pipe and the knob to dial the temp setting.
new one is very similar.. just looks different but has all the same things.
i have one main ignition switch wire, turns on when ign is on.
the other wire that hooks up to it switches the relay for the fan.
if i bridge the wires together... the fan works.. funny about that
if i hook it up to two of the termals on the new switch.. the fun is on all the time.. regardless of temp.. ive tried every possible combo for the three terminals, and turning the knob and heating the temp sender with no luck.. its either on or off..
before anyone pips up and says my wiring is dodgy.. its wired correctly so maybe the switch is kaput?! I bridged it together for no so i could get to work but its annoying having it on all the time.
any idea's?
Re: Thermofan question Thu, 07 August 2003 23:45 Go to previous messageGo to next message
I know this doesn't help your current problem, but what I did which might be an idea for you is get a factory 1 pin temp sensor from a auto parts shop.
They normally have lots of them and you can pick what you want in regards of the temp it switches on/off at.
I got one from a mitsubishi of some sort and it just earths the single pin at 90 degrees and opens again at 85 or there abouts.
Then all you need to do it run ign + to one side of the fan, and the other wire to the temp sensor. I had mine mounted in the radiator tank. But I know with 4AGE engines they sit in the thermostat housing.
The factory ones in 4AGE work a bit different, they pull away from earth to switch the fan on. Which is good as if the wire comes off or sensor breaks the fan will always be on.
Joel
Simon-AE86
Banned user
Re: Thermofan question Thu, 07 August 2003 23:57 Go to previous messageGo to next message
as i currentyly have the two wires, One which is power ignition on and the other is power to the relay to switch the fan..
how would i wire a single pin switch up?
are there any twin pin ones?
Re: Thermofan question Fri, 08 August 2003 00:10 Go to previous messageGo to next message
With the single wire ones, it usually is an earth so the +ve side of the fan you put ign + to, and the -ve side of the fan you put on the switch. Makes for a nice and simple circuit.
Joel
Re: Thermofan question Fri, 08 August 2003 00:11 Go to previous messageGo to next message
Should also mention.. the +ve to the fan is best to come from a relay that is switched on by ign+ or.... you could have the temp switch earth the relay and switch it on.. different ways to skin a cat!
Simon-AE86
Banned user
Re: Thermofan question Fri, 08 August 2003 00:22 Go to previous messageGo to next message
arrg ur confusing me Smile
im not good with auto electrics.. but anyway can i change what i have now to use a simple one pin type?
my relay is in an impossible spot to get to Sad
Re: Thermofan question Fri, 08 August 2003 01:04 Go to previous messageGo to next message
Haha sorry to confuse you dude...
Ok... if the relay is hard to get at we can leave that alone.
Fit a single pin temp sensor that pulls to earth when gets hot.
You have 2 wires coming off your thermo fan (or should anyway).. One is positive, one negative. Put the negative to the single pin temp sensor. Put the positive to the positive wire coming off the relay. Easy!
Joel
Re: Thermofan question Fri, 08 August 2003 01:12 Go to previous messageGo to next message
Hmm probably going to confuse you more but just re-read your original post.. Sounds like the current temp sensor you have switches the relay on.
So its impossible to get to the relay? As I could explain how to rewire it all nice and easy..
Re: Thermofan question Fri, 08 August 2003 01:15 Go to previous messageGo to next message
If you want email me @ joel_fitzgerald@hotmail.com if still all confusing..
Simon-AE86
Banned user
Re: Thermofan question Fri, 08 August 2003 01:31 Go to previous messageGo to next message
oh wait i get ya now!
so lest say i have it wired up as it is now with NO switch at all.. the positive ignition switch powering the relay trigger.. and fan is on all the time..
so.. i take the earth off the fan (whihc is wired to a chassis bolt for eath) and use that as a single pin relay? \
that makes sence! so when it reaches a temp.. it allows earth and the circut is then closed!
thats so simple even i could do it Very Happy
am i on the right track?
Re: Thermofan question Fri, 08 August 2003 01:36 Go to previous message
Ya got it mate! Haha funny how something so simple can be so damn hard to explain !
Previous Topic:Horn not working?
Next Topic:T-18 and AE86 parts interchangeability
Current Time: Sun Nov 1 03:54:59 UTC 2026
Total time taken to generate the page: 0.0069360733032227 seconds
