Toymods » Tech & Conversions » 1JZ - 4WD
dispatcher
Malaysia,Kuala Lumpur
1JZ - 4WD Fri, 08 August 2003 05:26 Go to next message
Anyone here done a mod like this ?? Using a 1JZ for a Prado 2.7petrol. My friend wants a 1JZ..but just rear wheel drive,If he wants 4WD can we use the transfer case ?? !!..any ideas or suggestions for other type of Turbo Engines greatly appreciated.
[Updated on: Sat, 09 August 2003 03:34]
ChuckLandwehr
Re: 1JZ - 4WD Sun, 10 August 2003 11:08 Go to previous messageGo to next message
Toyota Caldina station wagon 4X4 powered by 1JZGTE. That will get you a gearbox and transfer case that will suit a 1JZGTE.
E30-323ti
Re: 1JZ - 4WD Mon, 11 August 2003 00:04 Go to previous messageGo to next message
I think the Mark II came in 4wd format.
I recall seeing a JZX100 wagon on the net somewhere that was 4wd with a 1JZ-GE.
I think you will find that is a 3S-G(T)E in the caldina!!
Found something!!
http://www.auto.vl.ru/catalog/toyota/mark_ii/1998_ 8/
JZX105, they only seem to be in auto though.
I can't believe they put a 2L-TE in a *X10*, I would have thought a 1KZ if they had to put a diesel in one!!
[Updated on: Mon, 11 August 2003 00:29]
Re: 1JZ - 4WD Mon, 11 August 2003 00:47 Go to previous messageGo to next message
Aristo's are available in 4WD as well, with a 2JZ-GE engine. JZS147 or something like that.
E30-323ti
Re: 1JZ - 4WD Mon, 11 August 2003 04:45 Go to previous messageGo to next message
One way you could get some traction Norbie, go 4WD.
How is the JZA60 for traction with is semi-trailing arms??
Just curious because my E30 BMW has the same setup and they are known to be quite loose stock, let alone with a 1JZ in it.
Simon-AE86
Banned user
ADELAIDE - The Drift City
Re: 1JZ - 4WD Mon, 11 August 2003 05:06 Go to previous messageGo to next message
Norbie wants traction?
hahahahahahahahaha
Laughing
Re: 1JZ - 4WD Mon, 11 August 2003 14:19 Go to previous messageGo to next message
My Supra hooks up surprisingly well, which wasn't what I was expecting at all given the rooted LSD and dodgy suspension. The 12.49 ET proves there is a decent amount of traction available! Methinks it will have heaps of traction once I fix the LSD and replace the non-existent suspension bushes. Smile
Re: 1JZ - 4WD Mon, 11 August 2003 22:48 Go to previous messageGo to next message
Check this out! Very Happy
http://www.fullboost.com.au/racing/dragmeets/2003/willow_03_07_3/willow_03_07_3_043b.jpg
dispatcher
Re: 1JZ - 4WD Tue, 12 August 2003 03:12 Go to previous messageGo to next message
So baically, there's no prob to doing a mod like this, good. Now need to go find a Caldina...
Re: 1JZ - 4WD Tue, 12 August 2003 03:33 Go to previous messageGo to next message
As mentioned above, the Caldina has a 3S-GTE so that won't help you. After a bit of research I found out the 4WD Aristo's have 1UZ's and appear to be auto only, so that's no good either. Here's a bit of basic information:
http://www5f.biglobe.ne.jp/~oriental/hp-car/aristo -uzs143-zi-four-1993.htm
I guess that leaves the JZX105 Chaser/MarkII as your best bet. Good luck!
wagonist
Toymods Club Treasurer
Re: 1JZ - 4WD Wed, 13 August 2003 04:02 Go to previous messageGo to next message
Need to do a bit more research!
Caldina is only a small mid size car with an EAST-WEST engine.
It sits on the same floorpan as the Celica.
The Caldina GT-T was the successor to the Celica GT4.
As above, Crown wagon has 1J with 4wd, but is auto only, same as Aristo & Altezzas.
dispatcher
Re: 1JZ - 4WD Fri, 15 August 2003 02:42 Go to previous message
Did the PRADO LANDCRUISERS come with factory turbo engines ?? Diesel / Petrol ..
Previous Topic:MA61 brakes on AE86
Next Topic:connecting handbrake cable?
Current Time: Sat Nov 21 10:58:20 UTC 2026
Total time taken to generate the page: 0.0049979686737061 seconds
