Toymods » Tech & Conversions » 3tgte crank angle sensor?
ta22celica_boy
3tgte crank angle sensor? Fri, 08 August 2003 08:28 Go to next message
yeah i was just wondering if anyone had used this sensor on the 3tgte i waas talking to kevin at kp performance and he wasnt sure if the 3tgte had a c.a sensor. he told me that i could use one from a later model toyota, does anybody kno which toyota i could get it from?
thanks josh
TE72_Turbo
Re: 3tgte crank angle sensor? Fri, 08 August 2003 08:58 Go to previous messageGo to next message
I did a lot of research on this when setting up my 3TGTE, but found that no toyota CAS was easily modified to do the job. I ended up making an trigger setup with a hall effect sensor running off the crankshaft pulley (haltech ECU).
Maybe someone else has had better luck than me though....
Phil
ta22celica_boy
Re: 3tgte crank angle sensor? Mon, 11 August 2003 11:32 Go to previous messageGo to next message
thanks for the reply te72
kevin showed me one of these made by EMS but it retails $380 Confused!
how did it look and fit in your engine? the reason i wanted to get a crank angle sensor was so i could install a bigger plenum and throttle body, but the dizzy cap is in the way.
anyways thanks for the help
TA22-3SGTE
MACKAY
Re: 3tgte crank angle sensor? Mon, 11 August 2003 11:43 Go to previous messageGo to next message
Are you running the standard ECU and converting to direct fire or using an aftermarket ECU to run direct fire ?
Trevor
TE72_Turbo
Re: 3tgte crank angle sensor? Mon, 11 August 2003 12:00 Go to previous messageGo to next message
celicaboy:
give me your email address if you want a picture of the trigger setup on my 3TGTE crank. The hall effect sensor on its own was $150, plus $40 for magnets, plus aluminium & machining time.
I got rid of the dizzy for exactly the same reason, its a bit bastard, and gets right in the way of a custom plenum with front mounted throttle body!
Phil
ta22celica_boy
Re: 3tgte crank angle sensor? Tue, 12 August 2003 01:11 Go to previous messageGo to next message
yeah trevor im using an EMS computer
phil my email address is ta22celica_boy@hotmail.com. that price seems a little more reasonable Very Happy
thanks josh
YelloRolla
On your mum!
Re: 3tgte crank angle sensor? Tue, 12 August 2003 02:14 Go to previous messageGo to next message
I have a basic unit that I make (bracket for sensor and trigger disc). Uses the Wolf sensor (maybe they are the same).
Bracket + disc = $150 - straight bolt on. (I have a 3T GTE with which to fit it to make sure that it is correct)
The sensor from Wolf is about $75.
If I have another sensor I can make just about anything work.
I have done several Wolfs and TurboRA28 has made the disc that I use and bracket work with the Autronic.
EMP-2TG
Carlingford, Sydney
Re: 3tgte crank angle sensor? Tue, 12 August 2003 02:15 Go to previous messageGo to next message
could u email it to me to?
josh@kaizentek.com.au
TE72_Turbo
Re: 3tgte crank angle sensor? Tue, 12 August 2003 08:35 Go to previous messageGo to next message
emails sent Smile
Hey Jason, how does the Wolf sensor work? Is it a 2 channel hall effect that reads off a north & south pole on a magnet, or is it optical?
Phil
TA22-3SGTE
MACKAY
Re: 3tgte crank angle sensor? Tue, 12 August 2003 11:46 Go to previous messageGo to next message
Most aftermarket ECU's are made to trigger of a square wave ( hall switch ) some can be configured to trigger of either or both , If the ECU can be configured to trigger of a magnetic pickup like the toyota's use the 3TGTE dizy can be used as the main trigger but you will need another trigger setup somewhere for the home trigger which triggers before the main trigger No 1 ( to tell the ECU that the next main trigger is for No 1 cyl ) the No 1 main trigger usually is set to trigger about 60 to 100 Degrees BTDC No 1 .
I am using the 3SGTE dizy which I modified a little to run direct fire on my motor using Haltech E6S .
Trevor
YelloRolla
On your mum!
Re: 3tgte crank angle sensor? Wed, 13 August 2003 03:09 Go to previous messageGo to next message
Phil,
It uses a magnetic pick up with north and south as you have described it has another trigger for reference which is 15 deg or so before #1 TDC. Each of the triggers are approx 5mm high and run for 5 degrees duration.
I hope that this answers your question. Smile
TE72_Turbo
Re: 3tgte crank angle sensor? Wed, 13 August 2003 12:58 Go to previous message
Yep, spot on. Thanks Very Happy
Previous Topic:GA70 Supra 5 Speed - 4wd?
Next Topic:How do I identify my gearbox?
Current Time: Sun Oct 25 20:58:10 UTC 2026
Total time taken to generate the page: 0.044620990753174 seconds
