Toymods » Tech & Conversions » corolla performance
Audi-Tone
Brisvegas
corolla performance Fri, 08 August 2003 11:17 Go to next message
Hi, i own a 1984 corolla csx sedan and i've been told that if i take my air filter off (the whole thing) and run the carby as it is i would get more cold air into the egine, creating some more power?
or would i have to add a pipe and a different kind of air filter?
(bare with me, i'm noob Smile )
Thanx
Audi-Tone
manipulate
Re: corolla performance Fri, 08 August 2003 11:23 Go to previous messageGo to next message
OK
Think about it
what does the air filter do...
it filters air so its cleaner
this not only keeps the engine cleaner but it will actually perform better with cleaner air
but yes it creates a restriction thats true so u may notice a difference
put simply
i wouldnt
or if you HAVE to do so get a performance high flow air filter
Ta
Mani
Audi-Tone
Brisvegas
Re: corolla performance Fri, 08 August 2003 11:34 Go to previous messageGo to next message
thankyou for your kind kind input!
i realise this.. my mate, obviously doesnt care about his engine then..
no need to talk down like that...
manipulate
Re: corolla performance Fri, 08 August 2003 11:43 Go to previous messageGo to next message
calm down
i should have put a smiley face in there as tone is hard to percieve over the net
Smile Smile
was not having a go at you
one thing i cant stand is ppl that pay out noobs
Ta
Mani
Re: corolla performance Thu, 14 August 2003 11:12 Go to previous messageGo to next message
Audi-Tone wrote on Fri, 08 August 2003 21:17
Thanx
Audi-Tone
yup, pipe going from carby top to somewhere near the front of the car where there is cold air. you could use the good ol VN commondore airbox which is a whopping $30-40 genuine and comes with the panel filter! then put the intake form the box thru the radiator support somewhere, so it is not sucking in air prewarmed by the radiator (but not so it sucks in road dirt or rain)
you will notice a difference in summer, and may even get lower engine temps in hot weather. worthwhile doing cheaply, but not for over a hundred bucks...
Mazda626
Perth WA
Re: corolla performance Thu, 14 August 2003 11:16 Go to previous messageGo to next message
I took my air filter and top of the air cleaner off when i went down the 1/4 mile..
I noticed a diffence just my filter is kinda dirty plus for the little driving i did nothing much could get into the carby (i hope)
BUt if you notice a differnce then your filter is stuffed Smile
SW20R
Re: corolla performance Thu, 14 August 2003 12:05 Go to previous messageGo to next message
timing advance. give the dizzy a little turn and run 98ron
its safe, and a free mod until it detonates Laughing
[Updated on: Thu, 14 August 2003 12:06]
Mazda626
Perth WA
Re: corolla performance Thu, 14 August 2003 13:06 Go to previous messageGo to next message
Also adjust the valve clearance make them a little bigger should give it some more grunt Wink
Re: corolla performance Thu, 14 August 2003 14:39 Go to previous messageGo to next message
Mazda626 wrote on Thu, 14 August 2003 23:06
smaller? so the valves open more?
some air cleaners ar eterrible and you notice quite a large difference when you rip them off... some are not so bad at all..
if this 84 is a KE70 with 4K, the air cleaner is crap and should be stomped on then burned, then stomped on some more...
if it's an AE8x with a 4AC carby model, same theory applies Wink
they are both pretty restrictive, and you will probably notice a difference at higher rpms, but for tootling, difference is negligible.
even using the stock air cleaner, with no filter element inside, and running a pipe from the air cleaner inlet to a pod filter (suitably covered so it pulls cold air) or a panel filter box, may be better than the crappy round filter it has now...
but maybe not Wink
Mazda626
Perth WA
Re: corolla performance Thu, 14 August 2003 17:44 Go to previous messageGo to next message
i was thinkning of cam clearance Wink
IRA11Y
Club Member
Re: corolla performance Thu, 14 August 2003 19:51 Go to previous messageGo to next message
im curious.. how would that give you more power??? if you make the gap bigger from the lobe's max lift to the rocker arm then as far as i can tell all you would get is lots of cam noise (tappets) and bad clearances, therefore late valve action and lost power.. not to mention detonation.
please explain? Smile
Johnny
Sydney, OZ
Re: corolla performance Fri, 15 August 2003 02:23 Go to previous messageGo to next message
ditto that IRally??
mrk1rolla
Re: corolla performance Fri, 15 August 2003 02:34 Go to previous messageGo to next message
if the engine is a 4afc then you can buy a K&N filter to replace the standard paper filter, it fits exactly the same as the paper one.
However it does cost $140 Shocked
but i picked up a second hand one for $50, just needed a
clean Very Happy
RA28midge
Adelaide and Queenstown T...
Re: corolla performance Fri, 15 August 2003 03:14 Go to previous messageGo to next message
or just put a stocking over the carbie to keep any leaves out Laughing Laughing Razz and away you go.
munki
Gold Coast
My mate told me that if you take off the exhaust manifold there is heaps better flow at the expense of a little noise is this true?
i also put a bag of air in the freezer ready for the quarter mile do you think ill run 10's?
thanks you guys are the best!
[Updated on: Fri, 15 August 2003 03:17]
Mazda626
Perth WA
Re: corolla performance Fri, 15 August 2003 11:35 Go to previous messageGo to next message
i dont mean adjust them heaps..
I adjusted mine from 0.300mm too 0.4500mm
With datsuns(a12/14/15) they have been adjusted too 0.8 inlet and 0.5 exhaust with noticable perfomance changes..
IRA11Y
Club Member
Re: corolla performance Sun, 17 August 2003 05:04 Go to previous messageGo to next message
and what measurable performance gains did you get? got any figures? Im really keen to see if I can squeeze a little more out of my engine!!! Smile
gee ive played and rebuilt everything from A12's to L20's and ive never heard of that Sad can you tell me who has done it?? I would really like to talk to them so i can see what they did for the L20? as Ive been doing a bit of work with the one in my cousins 180B Rolling Eyes
Re: corolla performance Sun, 17 August 2003 14:13 Go to previous messageGo to next message
LOL, seriously tho, more clearance at the valves or cam means less duration and lift....
0.8mm clearance!!! holy shit!! did they tap themselves to death???
i would have thought more like 0.2mm would be better.. whay suge huge gaps?? doesn't it sound terrible??
and why larger gap on the intake when the exhaust valve expands more?
more info please... i'm a little miffed...
Razz Cya, Stewart
Seadog
Re: corolla performance Sun, 17 August 2003 23:58 Go to previous messageGo to next message
Yeah, I adjusted mine so that the cam nver even touches the valve and now it really flies!!
C'mon really??
longhairedgit
Falkirk Scotland
icon12.gif  Re: corolla performance Mon, 18 August 2003 21:15 Go to previous message
if you think about it valve clearances, bigger or smaller aren't going to have a lot of affect on lift or duration. thats set by the cam grind. it will however have an effect on your cam and valve train life. ie wear and tear. why do people get performance cams if it is as easy as setting the clearance? as for your air filter it's there to do a job too. filter. using a high flow filter or a bigger filter (more area to suck through) will have slight power gains yes. running a cold air intake with a ram effect like from a hole in the front spoiler to the filter box will really make a difference with a high flow filter. you would be crazy not to run with one. putting it in the freezer will last till you start your engine. colder air in, more O2 = more power to burn.....
Previous Topic:Steering Wheel Vibrates @ 100+km/h
Next Topic:anyone recommend a good Diff Shop in Sydney ?
Current Time: Mon Oct 26 11:54:45 UTC 2026
Total time taken to generate the page: 0.0054869651794434 seconds
