Classifieds » Miscellaneous » 550cc injectors
TE72_Turbo
550cc injectors Fri, 08 August 2003 15:14 Go to next message
Mazda 13BT injectors for sale.
Recently cleaned & fitted with new filters, flow tested to 550cc each. Top feed O-ring style (suit 7MGTE, 3TGTE, 2TG, 4AGE/ZE/TE).
$75 each ($300 set)
[Updated on: Mon, 11 August 2003 09:51]
cambelt
melb
Re: 550cc injectors Sun, 10 August 2003 14:49 Go to previous messageGo to next message
you wouldnt have two more would you
MR. 2
Parramatta
Re: 550cc injectors Mon, 11 August 2003 06:00 Go to previous messageGo to next message
where are u located?
MR11GT
Melb
Re: 550cc injectors Mon, 11 August 2003 07:03 Go to previous messageGo to next message
hi
does it require a custom fuel rail for the 550 injectors ??
TE72_Turbo
Re: 550cc injectors Mon, 11 August 2003 09:50 Go to previous messageGo to next message
david n:
Sorry mate, I only have the 4 injectors. You must have one tough 6 cylinder to need 3300cc of fuel!
Mr. 2
I'm in canberra.
MR11GT:
If you are fitting them to one of the engines in my first post (except for the 3SGTE, i accidentally typed that in, but they are side feed), then no, you do not need a custom rail, they are the same dimensions as the original injectors, only the injector plugs may need to be swapped.
Phil
TE72_Turbo
Re: 550cc injectors Mon, 11 August 2003 09:54 Go to previous messageGo to next message
If you have a 7MGTE, let me know, as I have 'heard' (for what its worth) that they do not all have the same injectors. The ones I compared were however the same as the mazda 13BT and should be a straight swap.
There will be other motors that these injectors fit also, such as the 18RG, just let me know if you need dimensions to check....
Phil
YelloRolla
On your mum!
Re: 550cc injectors Mon, 11 August 2003 10:19 Go to previous messageGo to next message
Phil, are they series 4 or 5 (rectangle plug top or oval)?
TE72_Turbo
Re: 550cc injectors Mon, 11 August 2003 10:28 Go to previous messageGo to next message
Rectangular plug, like the 3TG/2TG/18RG, with a spline down the middle. 2 ohm resistance (low impedance).
Nippon Denso
Part number 195500-1370
TA22-3SGTE
MACKAY
Re: 550cc injectors Mon, 11 August 2003 13:52 Go to previous messageGo to next message
TE72_Turbo
The ST165 3SGTE is top feed the later motors are side feed .
Trevor
TE72_Turbo
Re: 550cc injectors Mon, 11 August 2003 22:17 Go to previous messageGo to next message
Well there you go. Learning something new every day!
Are the two inlet manifolds (ST165 & 185) interchangeable?
TE72_Turbo
Re: 550cc injectors Tue, 12 August 2003 13:52 Go to previous message
*bump*
Previous Topic:Sprinter Parts, AE86 Springs, Struts, Shocks, Diff, Air Cond, Surge Tank, Injectors, Roof Rack
Next Topic:T50 Gearbox (20 spline)
Current Time: Wed Oct 14 04:36:50 UTC 2026
Total time taken to generate the page: 0.13946914672852 seconds
