Toymods » Tech & Conversions » Help need TRD parts
Bluewire
Adelaide, South Oz
Help need TRD parts Mon, 08 July 2002 09:33 Go to next message
Help.....Can you guys help me Question
Ive got a 18RGEU Twn Cam and fitting a SUPERCHARGER .
Got the engine getting rebuilt for the S/C but need low comp pistons.
Where can i get the low comp TRD pistons from .... here or over sea's
Classique71
Colac, Victoria
Re: Help need TRD parts Mon, 08 July 2002 09:51 Go to previous messageGo to next message
Cant help u with parts but id be curious about the 18rg and supercharger idea you have and how its planned to be done
A project ive been pondering for a long time is a Ra28 , 18rgeu with a 4agze supercharger on the side .. I reckon it would be heaps fun with good looks to match
KaosAD
Brisbane QLD
icon10.gif  Re: Help need TRD parts Tue, 09 July 2002 03:16 Go to previous messageGo to next message
I was talking to a guy in brisbane the other day and he has got a supercharger on his 2T celica engine in a TA22, i am now thinking about doing this as well, how do you decompress the engine so it does not destroy itself? and where do you get the pars from?
Classique71
Colac, Victoria
Re: Help need TRD parts Tue, 09 July 2002 03:39 Go to previous messageGo to next message
Hmms - hows he set up the supercharger on the 2t motor ? Mine would eb an awesome bottom end if it was swapped back to low compression ?? Any contact details on the person ?
KaosAD
Brisbane QLD
Re: Help need TRD parts Tue, 09 July 2002 03:46 Go to previous messageGo to next message
the person who i was talking to did no mods to the engine, just bolted up the supercharger and proceeded to root the engine. It only runs on 2 cylinders as it has blown the other two out and it still goes harder than any other celica i have seen.
he has just done it all dodgy, crappy pipes and dodgy mounting brackets and stuff but it goes hard and would go harder and last longer if it was set up properly eg. decompressed engine.
Classique71
Colac, Victoria
Re: Help need TRD parts Tue, 09 July 2002 03:49 Go to previous messageGo to next message
the 2tB in mines was a drag racing prepared engine - but at current its running high compression .. Id still like to know what supercharger he ised and if it was a blow thru setup or actually running off an EFI intake of some sort ..
Id need to dropthe compression considerably too - though a supercharger could be fun
KaosAD
Brisbane QLD
Re: Help need TRD parts Tue, 09 July 2002 04:36 Go to previous messageGo to next message
he had it set up carby -> supercharger -> stock carby manifold.
The charger he used was off a mitsubishi
how can i drop the compression on my 2T to accomodate the SC
[Updated on: Tue, 09 July 2002 04:38]
Classique71
Colac, Victoria
Re: Help need TRD parts Tue, 09 July 2002 04:44 Go to previous messageGo to next message
Stock 2t's run an 8.5-1 compression im pretty sure - though i believe the 8 or lower is better ..
A blow thru supercharger - hmms - in all honesty youd probably be better off with a already low comp 2tgeu ( aka tim frosts 4sefed ) and running it via the EFI system , bit i think its got somethign to do with the piston shape and rings to lower it best to create a new thread to get the question asked
KaosAD
Brisbane QLD
Re: Help need TRD parts Tue, 09 July 2002 04:46 Go to previous messageGo to next message
the guy said that he had a injector system for the 2T and that the charger off a 4AGZE and the injectors would work well
Classique71
Colac, Victoria
Re: Help need TRD parts Tue, 09 July 2002 04:52 Go to previous messageGo to next message
that would work depending on what he means by an injector system ( ie an aftermarket EFI system or an adapted one - with the 4a supercharger - and if it is actually for a 2t or not..
Tim frost used a 4agze supercharger on a 2tgeu - didnt need to change the internals of the motor - just needed tio get the supercharger piping right - then get the EFI computer mapping correct ..
Ended up getting an 85% HP increase over the standard 2tgeu though
Keep me posted - any pics too would be appreciated of the setup
KaosAD
Brisbane QLD
Re: Help need TRD parts Tue, 09 July 2002 04:56 Go to previous messageGo to next message
supposedly it is the stock injector system for the 2T (mabee imported)
Cant do pics sorry - no digi cam
The supercharger didnt root the stock engine? is it still going strong?
[Updated on: Tue, 09 July 2002 04:59]
Classique71
Colac, Victoria
Re: Help need TRD parts Tue, 09 July 2002 05:00 Go to previous messageGo to next message
as far as i knew all 2t's were carbyfied ? Hmms - maybe a later import model or something .. teh 2tgeu's were the only EFI 2t series that i knew of - UNLESS there was a 3t version that had inhection on the single cam block
Stuart
KaosAD
Brisbane QLD
Re: Help need TRD parts Tue, 09 July 2002 05:03 Go to previous messageGo to next message
the guy works for 'all jap' wreckers and importes - so it probably is off a import only car
Classique71
Colac, Victoria
Re: Help need TRD parts Tue, 09 July 2002 05:11 Go to previous messageGo to next message
proably a 3t-eu im giessing - thats the only EFI version of the t series thats single cam - the rest are twin cam ones ..
Hmms - if you got one of them - guesisng it bolts to the 2t head you might be lucky
Stuart
KaosAD
Brisbane QLD
I just started a new thread asking how to decompress a 2T engine -thanx for the idea, hopefully someone will know! Very Happy
Hopefully the guy will sell it to me and then i can work out the supercharger problems.
[Updated on: Tue, 09 July 2002 05:13]
inferno
Re: Help need TRD parts Wed, 10 July 2002 15:10 Go to previous messageGo to next message
yep there was an efi 3teu, but i'm sure that the inlet manifold pattern doesn't line up with a 2T inlet pattern, all the T series inlets were different. you could do a custom inlet but that would cost a fair bit.
hey KAOSAD, was the guy u were talking about called Ivan? if so then he used to also have a supercharged 2TG before the 2t that was killed when it was taken for a joyride. he got around 15psi before it died, and apparently did low 13sec 1/4miles. i want to supercharge my old 2t sometime, but inlets are the trouble. downdraft SU's were what the guy used on his 2tg i think, very expensive.
suck-thru setup is better than blow thru, and efi is better than suck-thru. efi is best by far.
i'll be interested how you go aswell since i'm still thinking of doing it myself.
also, i've got an 80thou copper head gasket for a 2T engine, which would lower your compression by about 1.5-2.5points.
rob
YOTA22
KaosAD
Brisbane QLD
Re: Help need TRD parts Thu, 11 July 2002 03:00 Go to previous messageGo to next message
would that gasket be enough to stop my rings being blown away. The guys name is keith and he works for a jap parts importer so he gets all his shit cheap.
If that gasket is all i need and you are willing to part with it - some sort of agreement could be made Cool
[Updated on: Fri, 12 July 2002 01:48]
inferno
Re: Help need TRD parts Thu, 11 July 2002 06:54 Go to previous messageGo to next message
yes, i got it made for my 2TG which had 9.8:1 compression, and i told the guy i wanted around 10psi out of it. not sure about your rings, i thought the only real problem was detonation, blowing up the pistons, but im thinking that if tim frost can use a supercharger with 8.8:1 compression, then you could supercharge a higher compression engine with this gasket.
It was made up for a 2TG and has the extra timing chain cover part which can easily be cut off for a 2T engine. I had it made-up from a guy in melbourne, who charged me $170 for it so i'm not real keen on selling it to you cheap.
damn i wish i worked there Sad
daytona
Wroclaw, Poland, Central ...
Re: Help need TRD parts Sun, 14 July 2002 07:42 Go to previous messageGo to next message
You guys seen this Supercharged 2T TA22?
http://members.fortunecity.com/daytona/othetoyo/jo ee.html
and
Classique71 , I think the SC12 off the 4A-GZE will be too small for the 18RGEU, the SC14 off the 1GGZE will be a better choice.
Laid'er
Classique71
Colac, Victoria
Re: Help need TRD parts Sun, 14 July 2002 07:51 Go to previous message
ive been tryign to find out details on that motor of ages - does anyone have any printed details or specs on it ???
I would love to do this to My 2tb - as i know the bottom end is strong enough to handle the boost - and my head is already worked over ..
I would need to lower the compression though
It appears hes running some sort of EFI setup and possibly an aftermarket blower ?? Can anyonwe confirm this ?????
Previous Topic:18RGZEU or 18RGTEU
Next Topic:RA40 conversion possibilities
Current Time: Sun Oct 18 19:58:18 UTC 2026
Total time taken to generate the page: 0.0091109275817871 seconds
