Classifieds » Parts Wanted » sprinter gearbox
TE72_Turbo
sprinter gearbox Mon, 08 July 2002 09:42 Go to next message
Does a normal 4AC sprinter gearbox fit a 4AGZE?
if so, who has one, where are you, and what price?
THanks in advance
fergo308
Eastern Sydney
Re: sprinter gearbox Mon, 08 July 2002 10:43 Go to previous messageGo to next message
a normal 4AC T50 will go behind a GZE,but you might want to treat it a little gently.
sprinter gearboxes are starting to become thin on the ground.
I've been after one for a couple of months now,as have a few other guys here.
Justin...
Mcninja
Re: sprinter gearbox Tue, 09 July 2002 05:48 Go to previous messageGo to next message
I have a gearbox in smick condition. Car used to belong to a granny, so it is in top condition. I will sell it for the price I got it for, which is 300 including delivery to your capital city (I am in Adelaide).
Cheerz,
Justin
king16
camden
Re: sprinter gearbox Thu, 25 July 2002 10:22 Go to previous messageGo to next message
if youv'e got a t50 (aus spec) behind a gze u might want to upgrade to a ae86 levin t50(jap spec)or treat the sprinter t50 really gently, i've got one cause im putting a 4age big port in mine and just to be safe im gettin a levin gearbox not quite sure whether im selling it yet but i'll keep you posted. and what sort of $$$$ would you pay for a aus spec gearbox? angus
TE72_Turbo
Re: sprinter gearbox Thu, 25 July 2002 10:53 Go to previous messageGo to next message
whats the difference? How would you tell them apart on the outside?
Sam
Sydney, Australia
Re: sprinter gearbox Fri, 26 July 2002 11:01 Go to previous messageGo to next message
king16, as far as I know both the jap and aus spec T50's have the same internals, the only difference is which side the clutch fork and slave cylinder are on (or is that the starter... no matter, same internals anyway).
jazae86
Re: sprinter gearbox Fri, 26 July 2002 15:46 Go to previous message
Sam's right: There is no diff internally between oz and jap T50. What is different is the spedo worm gear (jap is 4.3 or 4.1, oz is for 3.9 only, and I guess some jap are 3.9 aswell, but not that common as they usually brought in with 4AG's).
Oz has 3A bellhousing. Jap will normally have 4A, but some 3A. Difference: 4A has clutch fork on driver side. Both mount started passenger side. So now only the starter is heated by the exhaust with 4AG.
You can interchange the two. I'll be putting the 4A bellhousing I've got on my oz t50 and when she goes(280000Km), I'll put in on my jap t50 (which has 3A bellhousing, don't ask).
To the original question: using AE86 T50 will be a waste of money. If you are installing into Te72, then use TE72 T50's (I'm pretty sure they have T50's like older celica's). You may have to sort out a funky clutch as the input shaft has different spline number, but for the cost of early T50's, you could go through a few before the cost of 1 AE86 T50.
The clutch thing: normal 4A clutch's will be for late t50 with 24 (or 22) spline input, but the older t50 are 20spline or something. You would have to find a clutch that bolts to the 4a flywheel, or use a different flywheel, and appropriate clutch. Something in the back of my mind say honda civic or accord flywheel from some ancient toymods forum post: search the old forum.
Jaz
I think the above is correct, but it is late. I'd like to see more reply's before I'd be confident in doing anything, but it's worth thinking about as lots of the guy's I know are going through T50's in thier gze's, and there NOT cheap!!
Justin's gbox(which is sold to mate of mine) is pretty cheap. Usually $400 to $500 from wrecker's here in SA
Previous Topic:WTB: 20V Factory headers
Next Topic:2tg carb linkages
Current Time: Wed Oct 28 03:53:04 UTC 2026
Total time taken to generate the page: 0.0048739910125732 seconds
