Toymods » Tech & Conversions » 7A - GTE??
Rollin_AE102
Darwin NT
icon1.gif  7A - GTE?? Sat, 09 August 2003 09:02 Go to next message
Any body heard of the 7A-FE block with the 4A-GZE head??
If so oculd u guys provide any information on this conversion as i am looking to build a tough streetable motor for my AE 102
Ewan Evil or Very Mad
rvrolla
Central Coast
Re: 7A - GTE?? Sat, 09 August 2003 10:33 Go to previous messageGo to next message
http://www.geocities.com/strracerx/7agte.html
TA22-3SGTE
MACKAY
Re: 7A - GTE?? Sat, 09 August 2003 22:54 Go to previous messageGo to next message
http://www.turbofast.com.au/mr2.html
Ray hall has 1 in his MR2 at this link .
Johnny
Sydney, OZ
Re: 7A - GTE?? Sun, 10 August 2003 11:00 Go to previous messageGo to next message
I've just fininshed 7AGE, mircotech MTX-8 ECU and has currently clocked up 2000km's.... process to use the GZE is the same, but the 7AFE rods I would chuck and get some aftermarket ones as they won't last too long! Pistons from the GZE won't fit straight on the 7A rods, a small mod is needed, and there are two way you can go there. You'll need to run the 4AGE/ZE waterpump, and pulley's, alternator, definately use the GZE oil pump, it's heaps bigger. The Lower timing gear on the Crank has to be the 4AGE/ZE item, Porsche 944 timing belt fit's perfectly, I chose veriner cam gear's as the timimg for the 4A cams are a bit out when running them on the 1.8L, but it still runs without them. Power is currently down (55Kw@wheels) as the engine was way too tight and thrashing it on a dyno would cause too much harm, and it's currently running rich until it's worn in a bit. Another tune and head re-tensioning is now due, So this run would be better indication.
Jayem
Finland
Re: 7A - GTE?? Sun, 10 August 2003 11:28 Go to previous messageGo to next message
Here's a link but it's in Finnish. It says that they used 4A-GE cam wheels and Porsche 924S belt, 4A-GE pistons, 7A-FE conrods, 7A-FE flywheel and clutch. I can translate more if you want.
Jayem
Finland
Re: 7A - GTE?? Sun, 10 August 2003 11:29 Go to previous message
And the link was Embarassed ...
http://www.vhtracing.com/7atuning.htm
Previous Topic:Differnce between 2tg and 2tgeu thermostat ?
Next Topic: ATT: MODDED CAR OWNERS
Current Time: Tue Nov 24 19:11:31 UTC 2026
Total time taken to generate the page: 0.0050389766693115 seconds
