Toymods » Tech & Conversions » Rebuild kit for 4agze
Twinky
N.S.W
Rebuild kit for 4agze Mon, 08 July 2002 10:44 Go to next message
hey, where can I get a rebuild kit for a gze?? how much? or could I just use a normal 4age one???
thanks.
Twinky
N.S.W
Re: Rebuild kit for 4agze Mon, 08 July 2002 13:03 Go to previous messageGo to next message
anyone?
1bam777
Perth WA
Re: Rebuild kit for 4agze Mon, 08 July 2002 14:59 Go to previous messageGo to next message
Give the guys at Veales Auto Parts a call... they should be in the white pages. They usually stock parts for 4AGZEs here in Perth.
Darola
Taree, 4h nth of syd
Re: Rebuild kit for 4agze Thu, 11 July 2002 13:05 Go to previous messageGo to next message
Hey there, rebiuld kit, u just want seals?? or do u want bearings, rings, seals, gaskets, everything???
Darola
Ben Wilson
Re: Rebuild kit for 4agze Thu, 11 July 2002 22:07 Go to previous messageGo to next message
I'm not sure what all the differences are, but, I've been told the rings are different and the bearings I got had 4AGZE written on the box - I assume they were higher grade.
Do yourself a favour and get a genuine Toyota gasket set - It's a little more expensive, but, the amount of time you spend building up gaskets will make it all worthwhile.
._T_.
Re: Rebuild kit for 4agze Thu, 11 July 2002 22:22 Go to previous messageGo to next message
the early 4agze pistons run adiffernet ring set to other 4age's - i think the later 4agze pistons use the same rings as 100kw, but don't quote me on that.
bearings for a s/c & 100kw type/7 rib are all the same
T
Twinky
N.S.W
Re: Rebuild kit for 4agze Fri, 12 July 2002 03:24 Go to previous messageGo to next message
hey, yeh im after everything. Bearings, rings, seals, gaskets etc. They are for a ae92 afm gze. So where can I get such a kit to suit???
Thanks.
Darola
Re: Rebuild kit for 4agze Fri, 12 July 2002 07:21 Go to previous message
i will check out a price on monday for you, i work for toyota so i will get it alittle cheaper for you
Darola (Eddie)
Previous Topic:1JZ Basics
Next Topic:Which is Better....
Current Time: Sat Oct 17 06:07:25 UTC 2026
Total time taken to generate the page: 0.003896951675415 seconds
