Toymods » Tech & Conversions » squeaky ma61
STR8 2.8
squeaky ma61 Sun, 10 August 2003 03:39 Go to next message
squeaks coming from the engine bay.
around the aircon/powersteering/alternator
it squeakys when electricals are turned on (ie. headlights, aircon). but also during startup, it goes away now and then
it is quite annoying.
alternator belt mayb? worn brushes or something?
whats goin on?
cheers,
Chris
STR8 2.8
Re: squeaky ma61 Sun, 10 August 2003 09:52 Go to previous messageGo to next message
*bump*
help?
BlackSupra
Re: squeaky ma61 Sun, 10 August 2003 10:16 Go to previous messageGo to next message
Now anyone may want to correct this, and take this with a grain of salt if you will, but at work we fix squeaking drivebelts on treadmills with......soap.
We use a dry block of soap, hold it to the underside of the drivebelt and the noises dissapear, i was skeptical when told about it, but it does certainly work.....on treadmills at least.
I have no idea how this would effect the pulleys etc on the 5me thou.
Wait till someone with some knowledge on the belts pipes up, you may need a new belt if it makes noise. Confused
STR8 2.8
Re: squeaky ma61 Sun, 10 August 2003 10:20 Go to previous messageGo to next message
thanks bud,
an hows ur 2jz doin, michael said it was gonna happen a few weeks back but he never rang back..
manipulate
Re: squeaky ma61 Sun, 10 August 2003 10:23 Go to previous messageGo to next message
Theres nothing wrong with doing that black supra
first check to see if your belts are the right tension.... not worn...and the pulleys and pulley bearings are ok etc etc
and if its still making noise....use any lube....silicon lube works well but wd-40 or something similar should be fine
or just turn your stereo up
this is assuming its your belts though
Ta
Mani
[Updated on: Sun, 10 August 2003 10:30]
BlackSupra
Re: squeaky ma61 Sun, 10 August 2003 10:24 Go to previous messageGo to next message
Shocked
ed_ma61
Lost in the K hole
Re: squeaky ma61 Sun, 10 August 2003 10:29 Go to previous messageGo to next message
soap
STR8 2.8
Re: squeaky ma61 Mon, 11 August 2003 06:50 Go to previous messageGo to next message
cool thanks ill have a dig once hsc trials are over
BlackSupra
haha it will take 20secs
STR8 2.8
Re: squeaky ma61 Mon, 11 August 2003 07:15 Go to previous messageGo to next message
but that 20 sec could be well spent studying, or writing this msg which just took me longer than 20 sec... oooo shi..
STR8 2.8
Re: squeaky ma61 Sat, 16 August 2003 07:44 Go to previous messageGo to next message
mkay i slapped on some wd40 that did shit all?
mayb its the alternator itself?
it seems odd to me that it wud start to squeak all of a sudden if it was a loose/tight belt
the belt itself doesnt seem to have any issues
BlackSupra
Re: squeaky ma61 Sat, 16 August 2003 09:50 Go to previous messageGo to next message
did u use soap??
Allan
Re: squeaky ma61 Sat, 16 August 2003 23:10 Go to previous messageGo to next message
wd40 and slicon dont do shit rubber grease is what you use just a little on each belt (ie 5c coin ammount)
and soap does not last long
Allan
STR8 2.8
Re: squeaky ma61 Sun, 17 August 2003 01:17 Go to previous messageGo to next message
nah i didnt try soap
i didnt have any cheap bars of soap to waste
ill have to get some
rubber grease?
where do u get that?
any more information?
Allan
Re: squeaky ma61 Sun, 17 August 2003 03:13 Go to previous messageGo to next message
any auto parts place will have rubber grease its also used when puting brake parts together!
Allan
gold28
Madrid - Spain
Re: squeaky ma61 Sun, 17 August 2003 08:50 Go to previous messageGo to next message
If ya really want to get all teckanogical about it, here is a procedure you can use a mechanics stethescope (or a big long screwdriver) to check for bearing noise.
Disclaimer I don't advise this method and won't accept any responsibility for stuff ups causing bodily harm. But if you are the kind of risk taker that drives fast cars and lives life on the edge, you might want to give it a go.
Put the tip of the stethescope (screwdriver) on the alternator, power steering pump, air-con compressor etc and place your ear on the ear piece (handle). All bearings will all have some noise, but if a bearing is crook, you will know it.
CAUTION. I don't advise sticking your head in the fan belt or the screwdriver for that matter. Be very careful. It has taken me years of practice to master this technique. Kids.....don't try this at home.....
Sorry if this doesn't make any sence, I currently have the flu and ame appropriatly doped up, so if it doesn't make much sence (oops I just said that twice....how do I tell them that due to the drugging process I have lost my inner monologue Embarassed ) Well ask me next week.
STR8 2.8
Re: squeaky ma61 Sun, 17 August 2003 09:00 Go to previous messageGo to next message
hmmm im too young to die
Re: squeaky ma61 Sun, 17 August 2003 09:13 Go to previous messageGo to next message
pft
unless you're like me, and have long hair, you dont have too much to worry about.
I'malways really careful when under the hood with my engine running... one false move and I love a nice chunk of hair and scalp
gold28
Madrid - Spain
Re: squeaky ma61 Wed, 20 August 2003 03:09 Go to previous messageGo to next message
No it's not dangerous as long as you are careful. I wouldn't advise using a stubby screwdriver, just make it long enough to get your head well away from moving parts and as draven said, hair is easily removed.
It is an easy method to identify where bearing noise is coming from.
V8_MA61
Re: squeaky ma61 Wed, 20 August 2003 08:38 Go to previous messageGo to next message
lol watch your fingers!
I also have had a squeaky fan belt on my falcon..a product called "LANOX" by INOX is a product from lanoline, and it works fine.
STR8 2.8
Re: squeaky ma61 Wed, 20 August 2003 10:53 Go to previous message
im thinkin mayb it cud have something to do with the alternator
because the warning light comes on intermittently
although the noise has seemed to eased up Confused
Previous Topic:3s-gte query
Next Topic:4AGZE or 1GGZE supercharger onto Weber 32/36 carbed 5K
Current Time: Fri Oct 23 15:36:28 UTC 2026
Total time taken to generate the page: 0.024097919464111 seconds
