Toymods » Tech & Conversions » 20 valve running to rich how do i fix it.
2DVIOS
20 valve running to rich how do i fix it. Mon, 11 August 2003 00:36 Go to next message
hey, i just bought a corolla sx wit a 20 v is it but smoke is coming out of the exuast adn its running too rich how do i fix this, and how much will it cost.
also when teh car is cold it doesnt idle proply is there any way i can fix this.
the exuast i think it too big for the car its about 2 1/4 or 2 1/2 can this be teh problem for smoke blowing out all teh time.
if any one knows how to fix this let me know thanks.
Simon-AE86
Banned user
ADELAIDE - The Drift City
Re: 20 valve running to rich how do i fix it. Mon, 11 August 2003 01:08 Go to previous messageGo to next message
what ECU is it running?
Twinky
N.S.W
Re: 20 valve running to rich how do i fix it. Mon, 11 August 2003 03:05 Go to previous messageGo to next message
what colour is the smoke?
MR. 2
Parramatta
Re: 20 valve running to rich how do i fix it. Mon, 11 August 2003 03:37 Go to previous messageGo to next message
LOL what are u doing on here little brother.... LOL yeah the car is running a little rich its black smoke.... also on idle when cold its not idleing properly its just stalling!!! any ideas fellas also its the standard ecu which is strange also!
SW20R
Re: 20 valve running to rich how do i fix it. Mon, 11 August 2003 06:44 Go to previous messageGo to next message
do a check on the 02 sensor. these are the symptoms i had before when i had no 02.. or also vacuum sensors(map) and lines.
disconnecting your map will make it sound like a 13B bridge port Shocked cause the idle to play alittle and give you a hard time accelerating.
02 sensor will just look like a chimney.. and eat up heaps of fuel.
the exhaust size is fine. on cold mornings it would only give out white smoke which is moistured water burning of the tip.
02 sensors can be had from around $50-70? at neapean spares st marys.. just a generic brand called acl or something does the trick. comes with the sensor and flange
also just try cleaning out the throttle bodies,carbies with a spray
[Updated on: Mon, 11 August 2003 06:49]
2DVIOS
Re: 20 valve running to rich how do i fix it. Mon, 11 August 2003 10:25 Go to previous messageGo to next message
its running off the stock computer.
EvilJack
Sutho/Hills NSW
Re: 20 valve running to rich how do i fix it. Mon, 11 August 2003 11:25 Go to previous messageGo to next message
On the AFM there is a screw, you can turn this which will change your a/f ratios.
I tampered with this but cannot find the right spot, need a a/f gauge to correctly set it up.
seeks
Re: 20 valve running to rich how do i fix it. Tue, 12 August 2003 13:56 Go to previous message
Gday,
I'm interested to hear how you go, recently i got an o2 sensor for my silvertop 20v and it still appears to be running rich and a black carbony buildup on the rear bumper near the exhaust.
It's done this for 1-2 years now, maybe the engine is just a bit flogged out.
Thanks,
Seeks.
Previous Topic:gze oil question?
Next Topic:AE86 Brake Upgrade
Current Time: Thu Nov 19 01:40:12 UTC 2026
Total time taken to generate the page: 0.0045228004455566 seconds
