Toymods » Tech & Conversions » Throttle Body / Idle help please
SW20R
Throttle Body / Idle help please Mon, 11 August 2003 08:37 Go to next message
see diagram attached
http://members.optushome.com.au/michael.deleon/NA_140-E.gif
I assume the bottom facing ports are the water lines..
but what are the other ones?
i have played around and found if they are open they hold the idle up to about 1200-400RPM idle hot or cold.
How do i activate the abv for cold-idle setup again? (it only starts at 800RPM, and stays there hot or cold)
i know the top to the right are power steering functions (smaller size hoses) these are blocked off
but what are the lower ones facing the firewall of a fwd layout
[Updated on: Mon, 11 August 2003 08:43]
SW20R
Re: Throttle Body / Idle help please Mon, 11 August 2003 09:03 Go to previous messageGo to next message
can anybody do me a favour and take pics of there throttle body setup? and follow where the hoses go?
i've disabled the abv.. and drawn up where the hoses would go. can someone correct me/verify them
http://members.optushome.com.au/michael.deleon/DSC03246
[Updated on: Mon, 11 August 2003 09:37]
Re: Throttle Body / Idle help please Tue, 12 August 2003 07:03 Go to previous messageGo to next message
PCV hose?? look inside the throttle body, if there is black crap near one of the larger holes it will prolly be from the PCV valve. also depends if the tubes are before or after TB. after is vacuum, so brake booster, vac lines for MAP? and advance. before is usually emissions, ie fuel tank vent, PCV valve vent etc...
not that this really helps Wink
good luck, Stewart
bump
SW20R
Re: Throttle Body / Idle help please Tue, 12 August 2003 08:52 Go to previous message
is the fast idle for the 4AG connected right under the throttle linkage?
Previous Topic:Gear Box Ratio's
Next Topic:18RGUE Computer & Loom
Current Time: Sat Oct 31 13:17:10 UTC 2026
Total time taken to generate the page: 0.0053679943084717 seconds
