Toymods » Tech & Conversions » Removing crossmember mounts
Removing crossmember mounts Wed, 13 August 2003 10:08 Go to next message
Whats the best ways for removing the engine mounts off the crossmember? Can you just drill through the spot welds that are there?
I'm worried about just drilling the spot welds as it will end up looking like a cheese grater Confused
[Updated on: Wed, 13 August 2003 10:10]
wilbo666
Re: Removing crossmember mounts Wed, 13 August 2003 12:10 Go to previous messageGo to next message
Angle grinder? Confused
Re: Removing crossmember mounts Wed, 13 August 2003 12:15 Go to previous messageGo to next message
I want to reuse them Rolling Eyes
Jason
Re: Removing crossmember mounts Thu, 14 August 2003 05:59 Go to previous messageGo to next message
If you drill through the crossmember you will compromise its strength i think the only answer is the big chop with the grinder im affraid
roger
Re: Removing crossmember mounts Thu, 14 August 2003 06:16 Go to previous messageGo to next message
No don't use the grinder. I am not sure because I haven't done it but IDB in Richmond did mine and I have a friend unsticth a radiator support panel using this method. Drill the spot weld but don't penetrate the second panel ie cross member. Next get a cold chisel and belt the begeeses out of it until the rest of the weld breaks. I am told it is not hard to do.
roger
Jason
Re: Removing crossmember mounts Thu, 14 August 2003 07:03 Go to previous messageGo to next message
Yes but your still putting holes in the mounts so will this defeat the purpose (just a thought) Rolling Eyes
coronamark2
Re: Removing crossmember mounts Thu, 14 August 2003 07:04 Go to previous messageGo to next message
STOP
HAMMER TIME!
Re: Removing crossmember mounts Thu, 14 August 2003 08:49 Go to previous messageGo to next message
Ok I think i'll just use the drill.
coronamark2
Re: Removing crossmember mounts Thu, 14 August 2003 08:51 Go to previous messageGo to next message
You cant touch this
I've got mc hammer stuck in my head now Mad
roger
Re: Removing crossmember mounts Fri, 15 August 2003 04:35 Go to previous message
ha ha HAMMER TIME
I have holes in my mounts, still heaps of metal there, typically only 4 spot welds per mount heaps of metal let to weld the mount down. just don't drill through the cross member and you should be fine.
[Updated on: Fri, 15 August 2003 04:35]
Previous Topic:Installing Air/Fuel Ratio Guage - How Too? (4agze)
Next Topic:MA61 brakes on AE86
Current Time: Sat Nov 21 10:40:41 UTC 2026
Total time taken to generate the page: 0.0058510303497314 seconds
