Classifieds » Parts Wanted » headlight switch for jzx90 chaser
Chris Davey
sunny coast, qld
headlight switch for jzx90 chaser Thu, 14 August 2003 04:30 Go to next message
my headlight swith is faulty in my corona that has a jzx90 chaser dash. Anyone have the stalk that controls the headlights. That works Smile
chris
Chris Davey
sunny coast, qld
Re: headlight switch for jzx90 chaser Thu, 14 August 2003 11:55 Go to previous messageGo to next message
come on people, there are heaps of cars converted to 1j's, someone must have a headlight stalk?
Chris Davey
sunny coast, qld
Re: headlight switch for jzx90 chaser Fri, 15 August 2003 02:21 Go to previous messageGo to next message
Celia-Sue
Re: headlight switch for jzx90 chaser Fri, 15 August 2003 03:19 Go to previous messageGo to next message
Yep, got one. Was thinking of hanging on to the Chaser dash in the hope of one-day fitting the gauge cluster into the MA-61 - though I doubt I'll ever really get to doing it.
Is it just the stalk you want? If so, I guess I could part with mine.
Here it is: http://www.celicasupra.com/phpBB2/viewtopic.php?t= 2090
- Justin
Chris Davey
sunny coast, qld
Re: headlight switch for jzx90 chaser Fri, 15 August 2003 03:54 Go to previous messageGo to next message
sweet! I don't suppose you know if it works? Probably never had a battery hookup up to the front cut right?
I have a full chaser dash in my Corona but the headlight switch has burnt out and it only works when you fiddle with it between normal and high beam. How much would you want for it? I think you could test it pretty easily with a circuit tester light.
chris
Celia-Sue
Re: headlight switch for jzx90 chaser Fri, 15 August 2003 06:43 Go to previous messageGo to next message
I'll test it out next week and let you know how it works. I also want to do some measuring to see just how hard it would be to put the Chaser dash into the Supra. If it does look difficult - then we can agree on a price for the stalk - and anything else you might want/need.
cheers,
Justin
Chris Davey
sunny coast, qld
Re: headlight switch for jzx90 chaser Tue, 02 September 2003 11:32 Go to previous messageGo to next message
BUMP! Urgently Needed to finish my 1JZ Corona! Anyone?
BansheeBuzz
Gold Coast
Re: headlight switch for jzx90 chaser Wed, 03 September 2003 08:44 Go to previous messageGo to next message
in what way is the switch playing up? They can be repaired most of the time. I may be able to repair it for you.
Manny
Re: headlight switch for jzx90 chaser Wed, 03 September 2003 09:01 Go to previous messageGo to next message
Stalk looks the same as a 91-93 Soarer one.
Drop into an import wrecker and compare.
Chris Davey
sunny coast, qld
Re: headlight switch for jzx90 chaser Wed, 03 September 2003 11:19 Go to previous messageGo to next message
I rung the auto electricians to see if it can be repaired but he said it can't. It only works half way between parkers and normal lights so the contacts are stuffed and i have no idea how to pull it apart without breaking it.
I will be going down to the import wreckers this saturday and will compare. But i know there are even variances in the jzx90 chaser models so...?
hope they fit though Smile
Chris Davey
sunny coast, qld
Re: headlight switch for jzx90 chaser Sat, 13 September 2003 00:29 Go to previous message
BUMP!
Previous Topic:Need levin pistons
Next Topic:Gimme T50!
Current Time: Sat Oct 24 01:38:07 UTC 2026
Total time taken to generate the page: 0.0044410228729248 seconds
