Toymods » Tech & Conversions » Diffs can they be repaired ? !!
dispatcher
Malaysia,Kuala Lumpur
Diffs can they be repaired ? !! Fri, 15 August 2003 02:48 Go to next message
Can the diffs on say a Cressida GX60 or other models even be taken apart for repairs ??!!..my just converted 1G TT, rattles and vibrates under load..when the power comes on. Check and found an half inch freeplay. So looks like replacement is needed. Does anyone have ideas if the freeplay can be adjusted or are the rear gears shod. Also anyone knows of GX60 rear axles that come with discs ?? How much..?
Re: Diffs can they be repaired ? !! Fri, 15 August 2003 03:28 Go to previous messageGo to next message
Sounds like a pinion out of alignment. Yes it can probably be repaired, just take it to a diff shop!
Re: Diffs can they be repaired ? !! Fri, 15 August 2003 05:07 Go to previous messageGo to next message
I would also check the tailshaft.
-Mark-
Re: Diffs can they be repaired ? !! Fri, 15 August 2003 06:54 Go to previous messageGo to next message
I just picked up a Corona diff for $150, so I'd add 5o-100 to that. I guess of course.
Re: Diffs can they be repaired ? !! Fri, 15 August 2003 08:08 Go to previous messageGo to next message
Mark, he's in KL, Malaysia. Razz
dispatcher
I'm going out on a limb here..But how does a tailshaft look like, any pics ??..i might know it by some other name. Shocked
-Mark-
Re: Diffs can they be repaired ? !! Fri, 15 August 2003 08:10 Go to previous messageGo to next message
LOL
My BAD Smile
Re: Diffs can they be repaired ? !! Fri, 15 August 2003 08:15 Go to previous messageGo to next message
Driveshaft? The shaft that goes between the gearbox and the diff. The uni joints might be worn or thing might be out of balance.
dispatcher
Re: Diffs can they be repaired ? !! Sun, 17 August 2003 05:16 Go to previous message
Driveshaft, Tailshaft or whatelse.. Laughing Well it's ok maybe needs balancing and the diff needs somekinda repair or adjustments.....will work out and see how it runs.
Previous Topic:Aussie Springs
Next Topic:Flat TA22 Tailights Nightmare
Current Time: Sat Nov 21 02:54:05 UTC 2026
Total time taken to generate the page: 0.006641149520874 seconds
