Toymods » Tech & Conversions » throttle position sensor necessity
gabe
throttle position sensor necessity Fri, 15 August 2003 08:22 Go to next message
Just curious as to weather or not a TPS sensor is required if a MAP sensor is available?? after all, throttle position is directly proportional to manifold air pressure.......
An aftermarket engine management will be used also.
Re: throttle position sensor necessity Fri, 15 August 2003 08:26 Go to previous messageGo to next message
I would say yes as the 205 3s has a map sensor aswell as the TPS Confused
gabe
Re: throttle position sensor necessity Fri, 15 August 2003 09:08 Go to previous messageGo to next message
i do not want to hear that....... Confused
Re: throttle position sensor necessity Fri, 15 August 2003 09:40 Go to previous messageGo to next message
If you didnt read out loud you wouldnt of heard it Razz
Re: throttle position sensor necessity Fri, 15 August 2003 11:47 Go to previous messageGo to next message
gabe wrote on Fri, 15 August 2003 18:22
TPS is a necessity for working out acceleration and deceleration enrichments. the ECU should work out the fueling from the MAP vs RPM, but if you slam the throttle, it'll go momentarily lean without the TPS, and when you suddenly close throttle, it'll be rich without TPS.
the car will drive withouta TPS, but will be more responsive with a TPS.
GIN51E
Berowra-Sydney
Re: throttle position sensor necessity Sat, 16 August 2003 03:08 Go to previous messageGo to next message
My TPS isn't the best sort all it pretty much does is tell the computer if its closed or open,
thats why when i put the rally cam in i will have to go to an aftermarket TPS which can monitor every little throttle position otherwise i will have too much of a dead spot.
might give you something to think about.
sideshow
Re: throttle position sensor necessity Sat, 16 August 2003 04:32 Go to previous messageGo to next message
well if the computer didnt need it then they wouldnt have fitted it in the first place
Seadog
Re: throttle position sensor necessity Mon, 18 August 2003 00:02 Go to previous messageGo to next message
TPS is used for transients.
ie. The MAP tells ECU where the engine is but TPS tells it where it should be (where you want it to be). Hope that makes sense.
gabe
Re: throttle position sensor necessity Mon, 18 August 2003 05:05 Go to previous message
makes good sense actually.
though it means more rooting around for me....... Crying or Very Sad
[Updated on: Mon, 18 August 2003 05:05]
Previous Topic:Birthday!
Next Topic:Question about old Automatic Celica's
Current Time: Fri Oct 30 15:50:48 UTC 2026
Total time taken to generate the page: 0.0048549175262451 seconds
