Toymods » Tech & Conversions » Steering Wheel Vibrates @ 100+km/h
Asher
Northgate, QLD
Steering Wheel Vibrates @ 100+km/h Fri, 15 August 2003 10:02 Go to next message
I just had a full wheel alignment and everything else they do, and now the steering wheel vibrates when going at 100km/h+.
Whats the deal? should I take it back cuz they stuffed something up?
juzzo84
Hornsby, N.S.W
Re: Steering Wheel Vibrates @ 100+km/h Fri, 15 August 2003 10:35 Go to previous messageGo to next message
get the shocks checked out and also get the wheels balanced!!!
Stefan
Hobart, Tas
Re: Steering Wheel Vibrates @ 100+km/h Fri, 15 August 2003 10:53 Go to previous messageGo to next message
Same happened to me. I thought I had a suspension problem after I got new tyres, until I went to a better place and had my wheels rebalanced. Much better! Also, your one of your wheels may be out of round.
You could try swapping front&back and see if the problem changes, if it does it might suggest a wheel balance problem rather than a front susp problem.
need_boost
Re: Steering Wheel Vibrates @ 100+km/h Fri, 15 August 2003 10:54 Go to previous messageGo to next message
checked your tie rod ends lately?
Necros
Re: Steering Wheel Vibrates @ 100+km/h Fri, 15 August 2003 10:59 Go to previous messageGo to next message
My steering wheel does this too ;(
It all started when I got some 15" rims and new tyres put on... I was running spacers for the wheels. I then changed to a different offset rim and it helped a bit.... Sorta counts out wheels...
Whats the deal with tie rod ends?
STR8 2.8
Re: Steering Wheel Vibrates @ 100+km/h Fri, 15 August 2003 11:32 Go to previous messageGo to next message
i cant believe how much balancing actually does!
i had a spare on the front left and the steering wheel nearly broke my hands on the freeway, swapped the weights over and its smooooooth as!
Cyber-punk
Brisbane, QLD
Re: Steering Wheel Vibrates @ 100+km/h Sun, 17 August 2003 03:45 Go to previous messageGo to next message
Mine does this on and off
Somtimes i can get to 150 without it vibrating my arms off
Yet somtimes i hit 110 and i think my shoulders will pop out
Stefan
Hobart, Tas
Re: Steering Wheel Vibrates @ 100+km/h Sun, 17 August 2003 04:34 Go to previous messageGo to next message
Cyberpunk & Necros are your wheels aftermarket? If so, and they are lug-centric rather than hub-centric, that may well be youyr problem. Lug-centric (ie the wheel locates using the lugs, rather than a snug fitting centrebore on the hub) can be a PITA. You might need to get some rings made up so the centrebores of your rims sit snugly on your hubs.
Steve M
Re: Steering Wheel Vibrates @ 100+km/h Sun, 17 August 2003 07:41 Go to previous messageGo to next message
Have you flatspotted your tyres, this is why my brother's steering wheel vibrates at 80kph. Damn those kangaroos, they never know when to cross the road and not get hit.
Necros
Re: Steering Wheel Vibrates @ 100+km/h Sun, 17 August 2003 10:20 Go to previous messageGo to next message
Im using lug centric rims... Old skyline R30 rims so I dont know what else it could be ;( but its a pita.
[Updated on: Sun, 17 August 2003 10:22]
Asher
Northgate, QLD
Re: Steering Wheel Vibrates @ 100+km/h Sun, 17 August 2003 22:26 Go to previous messageGo to next message
Got a wheel balance done on saturday, all fixed, no vibrating and just general driving feels much better, only $15 so i'm happy.
Cyber-punk
Brisbane, QLD
Re: Steering Wheel Vibrates @ 100+km/h Mon, 18 August 2003 23:46 Go to previous message
Stefan wrote on Sun, 17 August 2003 14:34
yeah i have a dodgy AM formuling steering wheel...might look into this when i finally get a job Sad
*grumbles about moving interstate*
Previous Topic:Corona strut into Celica. Wheel question
Next Topic:corolla performance
Current Time: Wed Oct 28 08:31:49 UTC 2026
Total time taken to generate the page: 0.0055811405181885 seconds
