Toymods » Tech & Conversions » What diff ratio?
What diff ratio? Sat, 16 August 2003 10:10 Go to next message
Can anyone give me any ideas on what diff ratio I should choose for my car?
If you dont know, I have a TA22 with a 3S-GTE and a W58 box.
knackers
berala sydney
Re: What diff ratio? Sat, 16 August 2003 12:54 Go to previous messageGo to next message
hi cool1
what do you what to do with it cruise or drag or race it
And what ratio you got in it now.
cya knackers
Re: What diff ratio? Sat, 16 August 2003 12:57 Go to previous messageGo to next message
I want to cruise and drag at the track thats about it! And I dont know what ratio I have now, I just got the new diff Very Happy
knackers
berala sydney
Re: What diff ratio? Sat, 16 August 2003 20:44 Go to previous messageGo to next message
so is the diff centre in the car or still out
and the new centre you go what did the centre come out of
cya knackers
Re: What diff ratio? Sun, 17 August 2003 00:53 Go to previous messageGo to next message
Its a Hilux diff, So it will probably have some useless ratio! I have not used the car at all with the current engine and gearbox!
Re: What diff ratio? Sun, 17 August 2003 04:05 Go to previous messageGo to next message
Around 3.9:1 would be good IMO. Not sure how hard it would be to source a G series ratio that tall though.
Re: What diff ratio? Sun, 17 August 2003 07:56 Go to previous messageGo to next message
I might make some phone calls tomorrow and see what I can come up with Confused Or maybe I could just buy the 3.9:1 set from the same place Rod found.
knackers
berala sydney
Re: What diff ratio? Sun, 17 August 2003 08:40 Go to previous messageGo to next message
hi cool1
Well at a ruff guess i'd say it's running 4.1s
Was running 4.1s in my ute but it when like a slug so i found some 5.2s and well that got it happening.good luck
cya knackers http://www.minitruckzone.com/knackers/ Very Happy
Allan
Re: What diff ratio? Sun, 17 August 2003 08:41 Go to previous messageGo to next message
depends on what revs you want to be doing at 100kph down the hi-way preferably at the point your engine makes the most torque for least revs without boost in 4th gear that way you drop back the revs with overdrive
a OJ in the dark for you car would be a 4.1 or 3.9
my MA70 has a 3.9 and .71 over drive does 2200rpm at 100kph and isnt too bad of the mark for a big tank 3.54 would be ideal for the hi-way tho
Allan
Re: What diff ratio? Sun, 17 August 2003 08:47 Go to previous messageGo to next message
Well maybe I should just track down a second hand 4.1 center from the jap wreckers and try that! If I dont like it I can just buy a new 3.9 set later on.
FLY PSI
Re: What diff ratio? Mon, 18 August 2003 08:47 Go to previous messageGo to next message
Norbie wrote on Sun, 17 August 2003 14:05
i found that some MX83 cressies have 3.909:1 g series centre! Smile
the code on the compliance was G312.
Bugman
Re: What diff ratio? Tue, 19 August 2003 05:57 Go to previous messageGo to next message
I actually enjoy the 4.1 behind my 1g
running 15psi and a w58, it gets about 100km/hr out of 2nd gear ~150km/hr out of 3rd 200 out of 4th nd 250ish out of 5th.
I'm currenty running a 3.909 and it is only slightly different. I actualy found it to be worse at 100km/hr acceleration, where as the 4.1 seemed to be in a sweet spot to pull in 4th or throw it back to 3rd for a real pull
V8_MA61
Re: What diff ratio? Tue, 19 August 2003 06:41 Go to previous messageGo to next message
My 5me was doing 3000rpm @ 110km/hr in a w58 5th gear with a 3.9 ratio. Was too high imo. Should my 302 do the same revs providing i leave my box/ driveline the same?
Re: What diff ratio? Tue, 19 August 2003 08:37 Go to previous messageGo to next message
Thanks Luke, I might try a 4.1 first off and see how it goes.
Allan
Re: What diff ratio? Tue, 19 August 2003 10:13 Go to previous messageGo to next message
V8_MA61 wrote on Tue, 19 August 2003 16:41
You are aware cast iron v8's into ma61's have some serious heat issues? i suggest you track down v8supra (i think that was his name on here) he has an ma61 with a holden v8 and had issues with stuff melting
i would also think you may want a 2.something diff for that engine in an ma61 due to the fact you will need a few jerry cans straped to the back just to make it between servos, also you will be rowing thru gears like a lancer driver rice boy in the wet and the noise of all the push rods and stuff at 3000rpm will be deafining (ok last one im streching it a little)
Allan
V8_MA61
Re: What diff ratio? Tue, 19 August 2003 11:18 Go to previous messageGo to next message
What heating issues? Melting what?
Noise of pushrods and "stuff" at 3000rpm? A mates 351 cleveland revs to 7000 with no noise engine noise whatsoever. Cruises at 2800 - No excess sound. What type of engine are you basing this info on?
Holden v8's are significantly different to ford WINDSORs.
Too late to change my mind, blocks away being bored and have all parts here ready to go in.
Lets not debate v8s again please. I believe it is what got my cousin banned from toymods.
Btw is "suprav8" you're talking about.
[Updated on: Tue, 19 August 2003 11:19]
CrAiGzEE
south of the big smoke
Re: What diff ratio? Tue, 19 August 2003 11:27 Go to previous messageGo to next message
robbo i would hav thought a 3.7 would be better for the v8 application as ya wouldnt have to rev it to get speed
with the 4.1 it revs at 3000 at 100km/h bit high for my liking im gunna go 3.7 next
V8_MA61
Re: What diff ratio? Tue, 19 August 2003 11:29 Go to previous messageGo to next message
i think old falcon 302s used like a 3.1 ratio or something, so with anything over 3.5 it should be rather responsive. It should rev to around 6500 - 7000 given the mods ive done work to plan! So too low (below 3.5) ratio wont be the ideal one.
[Updated on: Tue, 19 August 2003 11:31]
TA22-3SGTE
MACKAY
Re: What diff ratio? Tue, 19 August 2003 12:21 Go to previous messageGo to next message
V8_MA61
A 302 Windsor with a bit of work done to it will go the best with a set of 4.1 gears , A stock Windsor works well with 3.23 gears . I put a stock Windsor in my sons 1990 hilux which had 4.5 gears and by about 90 kmh it was out of the torque range but it got bent like a banana before we could fit some higher gears ( Tried to move 50 meters of safety rails on a overpass one rainy night ) !!
Trevor
V8_MA61
Re: What diff ratio? Tue, 19 August 2003 12:24 Go to previous messageGo to next message
i think ill just keep the 3.9 the more i come to think about it. Just gotta think how much highway driving ill do...about 5-10 minutes a day i think.
V8_MA61
Re: What diff ratio? Tue, 19 August 2003 12:25 Go to previous messageGo to next message
sorry shane, i didnt mean to make a few posts in your thread! Razz
Re: What diff ratio? Tue, 19 August 2003 12:26 Go to previous messageGo to next message
I dont giveashit, I got what I needed out of it Very Happy
Re: What diff ratio? Wed, 20 August 2003 07:50 Go to previous message
Well it looks like the ratio I have now is a 4.875:1 which is very useless to me Sad So anyone want to buy some gears?
Previous Topic:Best Gear Box for RWD 20valve
Next Topic:hilux engine swap
Current Time: Sun Oct 18 01:16:55 UTC 2026
Total time taken to generate the page: 0.0068068504333496 seconds
