Toymods » Tech & Conversions » 2TGEU lack of reviness
Karl_skewes
New Zealand
2TGEU lack of reviness Tue, 09 July 2002 11:40 Go to next message
alright, considering this:
85mm bore
70mm stroke
Magnetic points
Double valve springs
9.8mm intake lift (2TG spec i think)
10.3mm exhaust lift (2tg again)
One would think that the engine would rev a bit higher. I have a lightened 6 or 6.5KG flywheel in mine, yet it gets all noisy after about 6000rpm. The engine is standard, with unknown kays, but 162-167psi compression test on the cylinders.
Timing is generally set at 12deg. More advance (upto 16) has been tried with greater bottom end and engine response, but lacking up top.... and vice versa with less base advance.
I've read that the valves tend to mushroom from hitting the seats when plenty of revs are used and bigger lift cams..
Some possibly explanations:
not all the balanced from factory
ecu has some sort of rev limit to prevent valve deformities
afm restricts air by enough to literally choke the engine.
So, any thoughts on this?
Jonny2TG
Tasmania
Re: 2TGEU lack of reviness Tue, 09 July 2002 12:35 Go to previous messageGo to next message
I'm having problems myself, but I'm on 40mm Solex carbies. I was thinking I may have a fuel pump problem, as it won't want to rev past 6000rpm. With standard cams, no engine is going to be making more power past 6000-6500rpm. A stock 2TG will sort of rev up to 8000rpm, depending on health and a number of things. It may not like it. You need to have longer duration cams to make power over 6500rpm. I have got mechanical noises as well, not sure what. Maybe a damaged valve spring, maybe the chain as well. Not sure.
If you want to run high rpm, the whole engine needs to be ballanced and assembled correctly with no error.
I havn't had experience with the 2TGE stuff. Maybe your injectors are maxing out due to low fuel pressure? It would be good to know what your fuel pressure was. Maybe the valve springs are a bit tired?
Get those "Group A" camshafts in and see what happens.
Karl_skewes
New Zealand
Re: 2TGEU lack of reviness Tue, 09 July 2002 22:13 Go to previous messageGo to next message
yeah, fitting that other head would be interesting with the cams.
My old 2TG engine used to rev out to 7000rpm, and I'd normally shift about 6750rpm.
Well, I can always change the regulator, but my LP pump will feed 4x375cc Injectors at 100% duty. My HP pump is off a soarer or something with 7MGTE engine I think, which is plenty for my little 2TGEU Razz
thetoyman75
Club President
Re: 2TGEU lack of reviness Wed, 10 July 2002 09:09 Go to previous messageGo to next message
Ignition Dwell can have a HUGE impact on the Reviness of a 2TGEU. If you have the electronic Ignition what ignitor are you using ? Different Ignitors have different Dwell settings.
The Ignitor from a 22RE appears to run them quite well.
You should easily be able to rev it past 6000 rpm it is running correctly. !
If that checks out I would be having a good look at the advance on your Dizzy. check the vacuum advance is still working and if possible get the internal weights looked at the also make a HUGE difference.
Karl_skewes
New Zealand
Re: 2TGEU lack of reviness Wed, 10 July 2002 10:04 Go to previous messageGo to next message
okay, the vacuum advance/retard probably isn't working, because at idle the advance doesn't change by connecting or disconnecting the vacuum hose.
If i blow into it, or suck on the hose, it doesn't affect the timing (using timing light), a new vacuum advance/retard mechanism is $96 + GST from Toyota.
Regarding timing weights...... is there anything I can see here, or do I have to dismantle the dizzy?
I'm using a standard 2TGEU ignitor.
thetoyman75
Club President
Re: 2TGEU lack of reviness Thu, 11 July 2002 00:00 Go to previous messageGo to next message
Karl,
With the car off take of the dizzy cap and disconect the Vacuum advance hose at the engine end (not the dizzy end). When you look into the dizzy you should be abble to see the inside part of the vac advance.
Suck on the hose and you should see it move towards the hose and in turn spinning the Dizzy babse anti clockwise. If you can suck air thru it or it doesn't move its stuffed !
If you can't suck air thru it and it doesn't move then givethe base a good clean you should be able to see where the base turns around the outside. It may just be gummed stuck.
As for the weights, I honestly am not sure how to check them I have mine done for me by Frank Kleinig at Girraween and they have actually been reset to give a base timing graph of 13 degrees and the vacuum advance is no longer used. That is in a Points type dizzy tho.
[Updated on: Thu, 11 July 2002 00:02]
Karl_skewes
New Zealand
Re: 2TGEU lack of reviness Thu, 11 July 2002 06:33 Go to previous message
sweet, I'll check it out this weekend.
Thanks for your help.
Previous Topic:Getting fuel and spark at points but motor wont start?
Next Topic:Cresidda Wheel Offsets Vs ST162 Offsets
Current Time: Wed Oct 14 09:36:13 UTC 2026
Total time taken to generate the page: 0.041869163513184 seconds
