Toymods » The Outhouse » Computer ruining TV reception, HELP :(
cam_RA40
Launceston, Tasmania
haha, funny little head!
Computer ruining TV reception, HELP :( Sat, 16 August 2003 11:55 Go to next message
hello, my new computer seems to interfer with the TV reception no matter where i put my computer in the house. does anyone know exactly what causes this and how i may be able to fix it? it is really annoying when my roommate wants to watch TV Sad
gtman
Re: Computer ruining TV reception, HELP :( Sun, 17 August 2003 04:32 Go to previous messageGo to next message
yeah I have a similar problem. I worked it out to be the modem. My dialup modem really screws around with the reception, when I turn it off its perfect, when I turn it on it goes out the window. I guess the best solution would be to get an outside antenna Confused
cam_RA40
Re: Computer ruining TV reception, HELP :( Sun, 17 August 2003 05:08 Go to previous messageGo to next message
I don't even have a modem Smile well not yet anyway. I have disconnected everything for a test and ran just the motherboard, ram & CPU. For some reason i think that it is the power supply, i may have to look in to getting a new antena, or maybe put the old rabbit ears on the roof Wink
EvilJack
Sutho/Hills NSW
Re: Computer ruining TV reception, HELP :( Sun, 17 August 2003 08:49 Go to previous messageGo to next message
its mainly the monitor that will do it.
i get it all the time, i find channel 9 to get hit the worst. Confused
EvilJack
Sutho/Hills NSW
Re: Computer ruining TV reception, HELP :( Sun, 17 August 2003 08:50 Go to previous messageGo to next message
[Updated on: Sun, 17 August 2003 08:50]
Re: Computer ruining TV reception, HELP :( Sun, 17 August 2003 12:56 Go to previous messageGo to next message
It will most likely be the power supply. Its usually the thing that is connected directly to the power that is causing the interference.
My mobile phone came from Hong Kong and has an adapter. Whenever it is plugged into the same room as our cordless phone my phone plays up and has mucho static.
boudan
Re: Computer ruining TV reception, HELP :( Tue, 26 August 2003 13:28 Go to previous messageGo to next message
agree on the power supply solution... try using a power board or alternate power source that wont cause electro pulse
Re: Computer ruining TV reception, HELP :( Tue, 26 August 2003 23:08 Go to previous messageGo to next message
Wrap your computer in a big bit of lead, that should fix it.
ae86drift
sydney.au
Re: Computer ruining TV reception, HELP :( Sun, 31 August 2003 13:39 Go to previous messageGo to next message
thank god for LCD monitors Very Happy
IRA11Y
Club Member
Re: Computer ruining TV reception, HELP :( Sun, 31 August 2003 22:20 Go to previous messageGo to next message
most likely cause is as stated above the electromagnetic pulse of the monitor creating interferance or intermodulation with the TV freq., another common cause is in older houses where the main earth used to be attached to the waterpipes, the easiest solution is to buy a earth spike and re-earth the house on the spike and not on the water pipes.... WARNING!!!! do not do this unless you are a fully qualified electrician.. there can be some terminal consequences if you dont know what you are doing!!!!!
the earth spike may solve some of the problem.... if your monitor backs on to the wall near where an eletrical cable runs try moving the monitor away and testing the TV channel to see if it makes any difference
you could also upgrade your coax to a better shielded type, this can be expensive but will most likely give you the best outcome
[Updated on: Sun, 31 August 2003 22:22]
Re: Computer ruining TV reception, HELP :( Mon, 01 September 2003 01:06 Go to previous messageGo to next message
expensive my butt! Razz
If you are not entirely a lazy person, upgrade all your cable yourself.
Now if you are one of those most unfortunate people who have the old school 300ohm ribbon cable, its not hard to see why distortion is so easily induced in your tv signal. Similarly can be said of dodgy RG59 coax and poor connectors etc.
My advice. Rip out all the existing cable and replace with RG6 QUAD SHIELD coax. This is the crud used for foxtel, optus, and satellite. Pinch a crimping tool off someone if you can and change all the connectors to the "F-type" (as with foxtel etc). If you can't get a crimping tool then stick with regular PAL TV plugs. If you have any splitters replace them also.
Cable worth $1.75p/m
plugs less than $2.00ea
Splitters less than $10.00ea
Hardly expensive Smile
IRA11Y
Club Member
Re: Computer ruining TV reception, HELP :( Mon, 01 September 2003 06:07 Go to previous messageGo to next message
comparitively speaking its expensive Smile compared to string its very expensive Razz
if you have to run 60m its definately expensive Smile
I thought quad shield was more than $2p/m? if not then that is what id use
Re: Computer ruining TV reception, HELP :( Mon, 01 September 2003 07:13 Go to previous message
Beldon brand quad sheid is like $2.35p/m
el-cheapo (still austel apprvd) quad sheild is $1.75p/m
string aint that cheap....Razz
Previous Topic:Fully Sick Auto's -
Next Topic:Puting Pictures in a Post
Current Time: Wed Nov 18 10:26:23 UTC 2026
Total time taken to generate the page: 0.005465030670166 seconds
