Toymods » Tech & Conversions » 1JZ plugs.. quick question
HedgehogSandwich
UK
1JZ plugs.. quick question Sat, 16 August 2003 11:56 Go to next message
Hi all.. quickie..
1JZ running 1bar on hybrids..standard fuelling.
best plugs?
adi
Soarer
Wollongong
Re: 1JZ plugs.. quick question Sat, 16 August 2003 13:11 Go to previous messageGo to next message
NGK BKR6E-8 gapped to 0.8mm (0.032")
you could also try
NGK BKR7E-8 but they may foul easily being a colder plug.
Don't even bother about platinum. You'll chew them up too quickly.
Re: 1JZ plugs.. quick question Sat, 16 August 2003 13:40 Go to previous messageGo to next message
how often do you guys change your plugs?
Guest
Re: 1JZ plugs.. quick question Sat, 16 August 2003 14:19 Go to previous messageGo to next message
BKR6E gapped to 0.8mm every 10000k's MAX or you'll develope misfires etc.
Dont get the new NGK v-grooves either they are crap and misfire from new when cold with no noticeable performance when hot.
Matt
HedgehogSandwich
UK
Re: 1JZ plugs.. quick question Sat, 16 August 2003 15:13 Go to previous messageGo to next message
Cheers all.. i'll change the next week. Ive been using standard Toyota plats for the last year and they could do with a change..
adi
2QIKMX83
SYDNEY
Re: 1JZ plugs.. quick question Sun, 17 August 2003 01:29 Go to previous messageGo to next message
Depending on ur copmuter system and how engine is tuned can determine plugs also, The new iridiums r shit, have gone through 3 sets in 3 1/2 months, fowl realy quikly and cause miss fires.
viagra_cressida
Balranald
Re: 1JZ plugs.. quick question Sun, 17 August 2003 12:38 Go to previous messageGo to next message
Soarer wrote on Sat, 16 August 2003 23:11
you could also try
Why not go platinum??? I thought they were better??
So I should go the cheaper ones and swap them more often?
Soarer
Wollongong
Re: 1JZ plugs.. quick question Mon, 18 August 2003 11:47 Go to previous messageGo to next message
Platinum/Iridium are fine for stock engines, but if you have a modified turbo engine or plan on doing it, save your $ and go copper/steel plugs. They are like $3 each instead of $30 each.
Modified engines put more stress on the plugs and the exotic ones just can't handle it. I know of a 1JZ that would eat a set of platinums in a weekend... expensive way to drive Sad
HedgehogSandwich
UK
Re: 1JZ plugs.. quick question Sat, 23 August 2003 15:38 Go to previous messageGo to next message
Which versions of the BKR6E do i need? I can get BKR6E-P, BKR6E-Y etc etc.. all differ masively in price.. any idea? Would a grade 7 plug be more security against detonation?
adi
[Updated on: Sat, 23 August 2003 15:45]
Soarer
Wollongong
Re: 1JZ plugs.. quick question Sun, 24 August 2003 01:30 Go to previous messageGo to next message
Just the plain old BKR6E plugs Adi. The -P at the end denotes Platinum which you don't want and I'm not too sure what the -Y denotes.
I am currently running heat range 7 in my 1JZ and haven't had any problems. They will foul easily if you have a stock 1J, but work fine if you have done a few extra mods.
HedgehogSandwich
UK
Re: 1JZ plugs.. quick question Sun, 24 August 2003 10:13 Go to previous messageGo to next message
I cant get plain old BKR6E ... there has to be another letter at the end of it.. i think Y is split groove.
Cheers for the info.. might try 7 if i can find them.
adi
Guest
Re: 1JZ plugs.. quick question Sun, 24 August 2003 11:00 Go to previous messageGo to next message
It might be BKR6E-S
S for steel.
Matt
gold28
Madrid - Spain
Re: 1JZ plugs.. quick question Mon, 25 August 2003 01:08 Go to previous messageGo to next message
The S is for STANDARD.
not sure what the Y is for.
viagra_cressida
Balranald
Re: 1JZ plugs.. quick question Mon, 25 August 2003 03:24 Go to previous messageGo to next message
Are the spark plugs easy to change in a 1992 Soarer?
My plug vover loos like the allen key things have been rounded Confused
I hope that won't make too many problems
Re: 1JZ plugs.. quick question Mon, 25 August 2003 05:01 Go to previous messageGo to next message
easy way to tell is to google for "NGK PLUG CODES"
the B, K and E describe the thread type on the plug,
the first number is heat range.
R is resistor (has an internal resistor to limit how much current and spark you can get.... has anyone tried non-resistor to see if you get electrical interference?? if you don't then you will get more spark energy across the gap with a non-resistor plug)
S is standard centre electrode
Y is for V-grooved centre electrode.
so for stock plugs BKR6ES
or v-groove BKR6EY
for colder BKR7ES, BKR7EY
for non-resistor plugs
BK6ES, BK6EY, BK7ES, BK7EY
if there is a number at the end, ie -8 or -11, that refers to the plug gap, ie 0.8mm, 1.1mm respectively.
colder plugs will foul at light load and idle, but will clean themselves when you give it some (since then they get into their temp range and burn off the carbon)
if you are fouling plugs often, then you need a warmer plug, unless a warmer plug will be too hot at worst engine conditions (ie WOT high rpm)
platinum are designed for low spark erosion in stock motors, with higher spark energy or higher temps, they will degrade quicker...
just a thought, the ppl that use plats very quickly.. are they using standard heat range or colder??? any plug running too hot will die quickly, be it plat or not....
HedgehogSandwich
UK
Re: 1JZ plugs.. quick question Mon, 25 August 2003 10:25 Go to previous messageGo to next message
Cheers... so if im running 1bar on the bigger turbos, presumably im increasing my risk of det and using a colder plug will help prevent this?
Soarer
Wollongong
Re: 1JZ plugs.. quick question Wed, 27 August 2003 13:14 Go to previous message
Yes, go the heat range 7 if you like. I'm running 7 with only exhaust & intake mods and they are great.
Previous Topic:acceleration problem
Next Topic:GZE Map ecu on a 4agte??
Current Time: Mon Oct 26 18:15:46 UTC 2026
Total time taken to generate the page: 0.0050098896026611 seconds
