Toymods » Tech & Conversions » GZE compression advice
Sprinta
GZE compression advice Sun, 17 August 2003 12:53 Go to next message
Hey dudes,
I have a bigport AE92 GZE AFM motor and im planning to buy an AE101 or late AE92 block with the 8.9 compression ratio.
What i want to know is, if i put the bigport head onto the map sensor version gze will the compression still be 8.9 or will it have dropped ?
Also what head gasket width do you guys recommend.. 0.8? 1.0? etc
Id want to keep it around 8.9 comp or drop it to about 8.7 as i want to run 16psi without any problems.. I run around 16psi at the moment on my 8.0 comp motor and its fine, but its getting a bit tierd and i dont want to do a full rebuild.
Reason i want to keep the big port head is because its running a turbo setup and i want to keep the inlet and exhaust manifold as they are.
Thanx in advance Smile
feral4mr2
Bundaberg, Qld.
Re: GZE compression advice Mon, 18 August 2003 08:55 Go to previous messageGo to next message
Freak you will have the same compression ratio regardless of what head you use. (8.9:1)
buy a genuine toyota 4agze head gasket.
you can buy metal shims from autoparts stores if you want to drop the c/r a little.
.5mm and 1mm i think they where when i last looked in the book at work.
Smile
Sprinta
Re: GZE compression advice Mon, 18 August 2003 09:22 Go to previous messageGo to next message
Thanx dude Smile
Do you know how much it drops when a .5mm or 1mm shim is used?
thanx Smile
feral4mr2
Bundaberg, Qld.
Re: GZE compression advice Mon, 18 August 2003 12:38 Go to previous messageGo to next message
Freak no i wouldnt know.
there is suppose to be some formular that you have to measure the bore, stroke, cc of the head or something.
to technical for me i'm afraid.. Laughing
Re: GZE compression advice Mon, 18 August 2003 12:44 Go to previous message
feral4mr2 wrote on Mon, 18 August 2003 22:38
Yeah but getting dressed is also to technical for you Twisted Evil Razz
Previous Topic:Broken Map Sensor Plug wire Melted My Cat
Next Topic:Car Radio Suppressor
Current Time: Tue Oct 27 08:07:50 UTC 2026
Total time taken to generate the page: 0.0040671825408936 seconds
