Toymods » Tech & Conversions » RWD 4AGZE engine mounts
moo4AGZETA22
Tasmania
RWD 4AGZE engine mounts Mon, 18 August 2003 03:30 Go to next message
I just thought I would share my experience. We have just put the 4AGZE in my Celica (74 model, TA22), and had to modify the Sprinter engine mounts and the Celica mounts. This is how we did the engine mounts.
1. When you look at the intake side of the engine, you will notice a black brace that supports the inlet manifold, and also a large S/C brace with 5 or so nuts and the one long bolt holding it on.
2. When you put the Sprinter mount on, it will not fit.
3. We placed several nuts on the back S/C brace bolt, and used an angle grinder with a 5 inch METAL blade to cut this of the S/C brace. Take your time, and you will not touch the engine at all.
4. Once this is done, take the nuts of the bolt (Stops the bolt from being damaged), then use a chisel or screwdriver to break the back part of the brace away.
5. The next problem is the black brace. Place this in a vise, and place a bit of pipe over it and gently bend the pipe till it fits with the engine mount on. Use only small bends at a time, and it should fit like a charm.
The engine mounts will be done the way that most suits you, so I'll leave that to your imagination.... I'll post some pics of the engine mounts and the cross-member mounts shortly.
Justin Rolling Eyes
Grega
melbourne.victoria.austra...
Re: RWD 4AGZE engine mounts Mon, 18 August 2003 23:50 Go to previous messageGo to next message
we kept the stock mounts welded to the ta22 x member when mounting up my 100kw motor.
we used the passenger side sprinter one on the passenger side, yet, very modified, and fabricated a new drivers side from an old 2T mount.
we're using ford cortina rubber mounts (same as what dorikan used in his conversion). my 4AGE sits pretty far forward but looks like it was meant to be there!
EVOSTi
cambo
      no
Re: RWD 4AGZE engine mounts Tue, 19 August 2003 11:26 Go to previous messageGo to next message
next time i got the bonnet up on the missus' ta22 ill take some pics of her engine mounts with 4age, just for comparison Very Happy
Grega
Re: RWD 4AGZE engine mounts Tue, 19 August 2003 22:04 Go to previous messageGo to next message
yes please dude
i'll do same with mine.
Grega
Re: RWD 4AGZE engine mounts Wed, 20 August 2003 06:38 Go to previous message
well here u go
drivers side
http://www.vncommodore.com/images/celica/ta22mounts1.jpg
passenger side
http://www.vncommodore.com/images/celica/ta22mounts2.jpg
and what 100killer watts looks like in there
http://www.vncommodore.com/images/celica/ta22mounts3.jpg
Previous Topic:Gt4 Suspension advice needed !
Next Topic:can i use S-AFC?
Current Time: Thu Oct 15 13:34:53 UTC 2026
Total time taken to generate the page: 0.041592121124268 seconds
