Toymods » Tech & Conversions » Help - My Dyno Graph!!!
troyboy
Colyton, NSW
icon8.gif  Help - My Dyno Graph!!! Tue, 09 July 2002 14:05 Go to next message
Nope
Hi peeps,
please help.. what can I do
What does this mean... BigWorm says its bad...
(no no the KW the AFR)
help!!!!!!
http://members.optushome.com.au/cre34m/dynograph2.jpg
Nark
Cabramatta, NSW
      Nark@toymods.net/Work
icon4.gif  Re: Help - My Dyno Graph!!! Tue, 09 July 2002 15:54 Go to previous messageGo to next message
Wow!! Goes from mega-lean to mega-rich!!
I didn't know that you could run that lean off idle!!!
Are you using the factory ECU or an aftermarket one? Is your engine AFM or MAP?
Do you have an air filter? What type of exhaust?
troyboy
Colyton, NSW
Re: Help - My Dyno Graph!!! Tue, 09 July 2002 22:15 Go to previous messageGo to next message
OK...
Standard ECU
MAP
2.5 Mandrel Bent Straight Thru Resonator.. (on that dyno)
usually run around with normal rear muffler .. cause thats legal noise..
the straight through is at like 115dB
GTI16V
CROMER, NSW
Re: Help - My Dyno Graph!!! Wed, 10 July 2002 05:59 Go to previous messageGo to next message
That is bad,there has to be something a miss.
Pumpkin
Toymods Board Member
Re: Help - My Dyno Graph!!! Wed, 10 July 2002 06:40 Go to previous messageGo to next message
Would the front mount intercooler have something to do with it ???
IRA11Y
Club Member
Re: Help - My Dyno Graph!!! Wed, 10 July 2002 06:45 Go to previous messageGo to next message
what engine are you running?
thetoyman75
Club President
Re: Help - My Dyno Graph!!! Wed, 10 July 2002 08:58 Go to previous messageGo to next message
Michael,
Pretty sure Troy has a 4AGZE mate !
Allan
Re: Help - My Dyno Graph!!! Wed, 10 July 2002 11:22 Go to previous messageGo to next message
thats not bad mixtures!
http://home.useoz.com/~allanlangford/allandynographsmall.jpg
THATS bad mixtures...
Anyone able to get the original dyno files for us? someone said somewhere you can get a viewer to show the torque graphs too?
Allan
[Updated on: Wed, 10 July 2002 11:23]
BigWorm
Turramurra, Sydney.
Re: Help - My Dyno Graph!!! Wed, 10 July 2002 13:26 Go to previous messageGo to next message
Haha, jeez allan, if that was my dyno sheet, I'd be telling everyone the top line is the power curve! hehehe
Ribbo
Northern Beaches
Re: Help - My Dyno Graph!!! Wed, 10 July 2002 14:06 Go to previous messageGo to next message
here is more what you want Rolling
http://members.optushome.com.au/gregmatt/pics/dyno.jpg
good old microtech digi 1 Laughing
and why is my gearing so crazy high?
I didn't see anyone with such high like I nearly hit 190km/h
[Updated on: Wed, 10 July 2002 14:08]
troyboy
Colyton, NSW
Re: Help - My Dyno Graph!!! Wed, 10 July 2002 14:21 Go to previous messageGo to next message
she's a gze alright...
so .. what can be done...
hmmm
Nark
Cabramatta, NSW
icon1.gif  Re: Help - My Dyno Graph!!! Wed, 10 July 2002 14:39 Go to previous messageGo to next message
Troy, I'm pretty stumped. Can MAPs go suspect? Is your air filter clean? How much advance are you running?
Ribbo, same here... Clocks out to about 190km/h. But my graph keeps going up... Doesn't stop at 60kW.... hehehe
http://www.toymods.org.au/Nark_Celica/Dyno%20Day%205%20Graph.png
The blue line is my power after the timing was retarded to stop the pinging... I prolly lost half your graph at some points.... Grin
Sorry, just having fun with you 4A girls... Rolling
BigWorm
Turramurra, Sydney.
Re: Help - My Dyno Graph!!! Wed, 10 July 2002 14:52 Go to previous messageGo to next message
You guys want me to put my graph up so you can all have a good laugh at it? Embarassed
It is pretty funny. Laughing
Pumpkin
Re: Help - My Dyno Graph!!! Wed, 10 July 2002 22:48 Go to previous messageGo to next message
You still beat me Bigworm Laughing At the moment we are pretty much neck and neck, when you find that lost power .. I'm in trouble... Shocked
Damn...hhhhmmmm... Where did I put that turbo...??? hehehe
Joshstix
Toymods Vice President
Re: Help - My Dyno Graph!!! Thu, 11 July 2002 02:07 Go to previous messageGo to next message
There is always a lot of discussion about this on the MR2 message board. Apparently this always happens when you put an oversize pulley on the MAP sensed 4AGZE. There are a bunch of people working on trying to get the mixtures richer under 3000 RPM on boost, apparently interceptors and things aren't helping.
The final mixture is pretty reasonable but you really want it to get down there much earlier. Programmable injection is the answer, expensive and inconvenient but if you want more power out of your GZE that's the way to go. This also allows you to have the supporting infrastructure to go to a Turbo when you're sick of the sluggishness up high from the superchager.
troyboy
Colyton, NSW
Re: Help - My Dyno Graph!!! Thu, 11 July 2002 02:34 Go to previous messageGo to next message
hmm..
what sorta figures... and whatl it eventually cost?
roughly
jza70-mel
Perth WA
Re: Help - My Dyno Graph!!! Thu, 11 July 2002 12:55 Go to previous messageGo to next message
Or the other solution would be bigger injectors, then bring them leaner at a higher rev range with an intercepter.
Does it actually ping at 16:1? What boost is it reading at this level?
BigWorm
Turramurra, Sydney.
Re: Help - My Dyno Graph!!! Thu, 11 July 2002 15:32 Go to previous message
Hey, that's a good idea with the injectors, but instead of the inteceptor, all you'd need would be a bleed valve on the vac/boost line to the fuel pressure regulator.
I remember something in a recent zoom magazine where someone was making something like this, specifically for fuel press. regs.
It would be funny pointing out a turbo smart bleed valve in your engine bays, just think the stories you could make up when people say "but it's a supercharged engine???" hehehe
[Updated on: Thu, 11 July 2002 15:33]
Previous Topic:flycut depth
Next Topic:microtech D4 problems
Current Time: Sat Oct 17 13:32:12 UTC 2026
Total time taken to generate the page: 0.0053300857543945 seconds
