Toymods » Tech & Conversions » 1JZ ignition problems
wastegate
Gold Coast
1JZ ignition problems Tue, 19 August 2003 04:31 Go to next message
Ok, my 1JZGTE seems to be having a couple of problems.
First of all the mods,
600x300x90 Bar and Plate cooler
2.5 and 3" SS Mandrel IC Piping
2.5" Dual Dumps straight off the turbos.
K&N Pod Filter
There is no boost control used.
Now at around 0.9bar - 1bar I am having the ignition breakdown and misfiring. I have hit 1.1bar and hit the boost cut so I know it's not that.
I have changed from the platiums to coppers with 8mm gap, no change.
I have changed the coils for 2JZ ones (same) and made no difference.
I have changed the igniter for a 2JZ one (same) and made no difference.
We did notice that the Map sensor was plugged into the wrong port on the plenum so we fixed that and plugged it into the filtered one. It fixed the problem for about a day but now it is back. Could a dodgy map sensor cause this?
The car seems to overboost though so I thinking that is a stuck wastegate and/or leaking wastegate line also.
1JZ.747
Osama's hideout
Re: 1JZ ignition problems Tue, 19 August 2003 05:02 Go to previous messageGo to next message
do you have an immobilizer.
i had a similiar problem and it turned out to be the earth screw for the immobilizer had been attached to a screw that held the kick panel in and every time i hit boost the screw would move and the ingnition would break down, once i drilled it straight into the body work problem solved. thanks to my brant installer for that one.
it may not be your problem but i over looked this for weeks, changing coils,ingnitors, spark plugs.
just a thought
shane
wastegate
Gold Coast
Re: 1JZ ignition problems Tue, 19 August 2003 06:35 Go to previous messageGo to next message
Thanks for that, I'll have a look over all the earths as well.
Grant
Newcastle, NSW, Australia
Re: 1JZ ignition problems Tue, 19 August 2003 22:03 Go to previous messageGo to next message
If this is a conversion, make sure you have a good power supply to the igniter. A drop in voltage (even slight) can cause this.
Re: 1JZ ignition problems Tue, 19 August 2003 23:00 Go to previous messageGo to next message
8mm plug gap is pretty keen Evil or Very Mad
wastegate
Gold Coast
Re: 1JZ ignition problems Wed, 20 August 2003 00:24 Go to previous message
Well I solved it, well it's not doing it now anyway. I used a better screw. Yup the screw that was holding the map sensor to the firewall was coming loose. I changed it and now it's tight yas twight on the firewall and it's not doing it. I'd say the Map sensor must earth also this way even though it has a earth wire.. bizarre.
Previous Topic:Soarer LSD
Next Topic:bushes in front end of sprinter
Current Time: Wed Oct 21 11:54:39 UTC 2026
Total time taken to generate the page: 0.0049571990966797 seconds
