Toymods » Tech & Conversions » 3tgte service specs etc
celiboy18
3tgte service specs etc Tue, 09 July 2002 16:49 Go to next message
g'day
just wondering what i should use when servicing my 3TGTE
-what type oil
-plugs and gap
-oil filter
-fuel filter (going to have to match it up, some dude put a holden efi filter on it)
-whats the timing degrees ?
-diff oil (what type)
-gearbox oil (what type)
and any other info i might need to know
celiboy18
Re: 3tgte service specs etc Wed, 10 July 2002 12:11 Go to previous messageGo to next message
anyone?
Re: 3tgte service specs etc Wed, 10 July 2002 12:16 Go to previous messageGo to next message
The brand of oils and filters are much of a muchness! Personal preference really! You should be able to find the grade of oils in a Haynes manual!
Gaps and timing you should also be able to find in the Haynes manual!
If you go to autobarn or simlar, they will be able to tell you what grade oil to use!
celiboy18
Re: 3tgte service specs etc Wed, 10 July 2002 12:32 Go to previous messageGo to next message
i actually wanted opinions of people that have 3TGTE's and what they use Smile
ohh and, i dont think you will find my car in a haynes manual.. hence my posts
TA63 Celica GT-T.. cant find specs for a 3tgte where ive looked, so yeh..
also got the IRS rear end
[Updated on: Wed, 10 July 2002 12:36]
Jonny2TG
Tasmania
Re: 3tgte service specs etc Wed, 10 July 2002 14:32 Go to previous messageGo to next message
Engine oil: probably 15-40w where they say it is for turbo or deisel use.
Oil filter: probably same as 3T and 2T motor, change it as often as you like.
Plug gap: about 1.1mm would be good for electronic ignition. Not that critical with a good coil. I have no experience with this motor.
Fuel filter: Realy, just about any efi filter should work. As long as you have the right connections to make it tight. If you want a toyota one, then order it to suit a RT144 corona or something.
Diff and gearbox oil: any GL5 should be good. About a 80/90 weight. Soemthing that says high pressure on it, for Hypoid gears, and LSD. Any GL5 would cover that.
Base timing would have to be around 10 degrees, not sure.
Re: 3tgte service specs etc Thu, 11 July 2002 01:13 Go to previous messageGo to next message
Hello..
I am currently running BP Corse Plus oil.
NGK BP7ES spark plugs with a .8mm gap
Oil filter, forget the model but it is from a 2T engine. Z89 maybe?
Fuel filter is from a Nissan 300ZX
Timing is 10 BTDC. There is 2 marks on the pulley, one for TDC and one for 10 BTDC.
Gearbox oil I use a castrol which basically states on the bottle that it suits all toyota 5spd gearbox.
Diff oil, no idea never changed mine before.
Hope this helps.
Joel
daytona
Wroclaw, Poland, Central ...
Re: 3tgte service specs etc Thu, 11 July 2002 04:26 Go to previous messageGo to next message
I used,
Pennzoil for Turbo's (cant remeber the details)
NGK BP7ES with 1.1mm gap
Original Toyota Oil Filter, this is a very small one, its the best out there. Made for 3S-GTE engines I think, if you want I can get you the part number.
Gearbox Oil was the Castrol that Toyota uses, fixes gbox crunches, and gears go in better when cold.
Used the same in the diff. But if you have a LSD you might want to get some specific oil for that, or somthing you add to the oil
I had some camry fuel filter, and ran as much advance as I could without pinging.
Laid'er
TE72_Turbo
Re: 3tgte service specs etc Thu, 11 July 2002 09:26 Go to previous messageGo to next message
yeah, pretty much same as you guys,
oil filter: Ryco Z89A (same as 3T-C)
Fuel filter: Ryco Z200 (as used on holdens, nothing wrong with these, nice and compact too)
gearbox oil: castrol 80/90
diff oil: if you have LSD make sure you use the right oil! check with a gearbox/diff workshop
timing: I thought the second mark on the pulley for base timing at idle was 12 degrees? I'll check this...
plugs: NGK BP7EY, you might want BP6EY if you run stock motor & boost. gap: 1.1mm
engine oil: your choice dude! I run penrite pedigree.
celiboy18
Re: 3tgte service specs etc Thu, 11 July 2002 12:27 Go to previous messageGo to next message
thanks for the replies..
te: whats the difference with the plugs that you have told me and the ones they have told me?
thanks in advance
TE72_Turbo
Re: 3tgte service specs etc Thu, 11 July 2002 14:39 Go to previous messageGo to next message
BP7EY is a y-grooved centre electrode
BB7ES is a standard electrode.
the difference between 6 & 7 is the heat range. 6 would be better for a standard motor/standard boost, but might cause detonation & cant take the heat on higher boost, where a 7 would be better on higher boost, but foul easier on a standard motor.
Hope that makes sense, i've just got back from the pub.
Phil
ta2272
Re: 3tgte service specs etc Thu, 17 February 2005 01:35 Go to previous messageGo to next message
When i went they did not have the Y's so i just got the s's there wouldnt be that much loss???
Jason
Toby
March 2005
Re: 3tgte service specs etc Sun, 28 August 2005 15:23 Go to previous message
Sorry to ask a question here, but it seems better than starting a new thread.
Does anyone know what the compression for a 3TGTE should be ??? I've just done a compression test on a car I purchased and it came out pretty low, around 135. I'm just wondering if this is normal ?
Any help would be great Smile
P.s. All the other info in this thread was really helpfull! Thanks everyone Smile
Previous Topic:ae82 and ae92 gearbox
Next Topic:How strong are my Internals?
Current Time: Wed Oct 28 19:31:20 UTC 2026
Total time taken to generate the page: 0.047643899917603 seconds
