Toymods » Tech & Conversions » ae92 4agze lsd gearbox in to a ae82 pls help
tin can
ae92 4agze lsd gearbox in to a ae82 pls help Tue, 19 August 2003 09:20 Go to next message
people people i need help badly and i mean most prob tonite hopw do u fit a 4agze ae92 gearbox to a ae82 twin cam what is needed pls help need car going by jamboree thanks all Laughing
[Updated on: Sat, 23 August 2003 02:43]
tin can
Re: how do u do it Fri, 22 August 2003 12:48 Go to previous messageGo to next message
can some one pls help some one must have done it before i no its possible but i want to do the frist time right pls help pls thanks all
Re: how do u do it Fri, 22 August 2003 14:22 Go to previous messageGo to next message
maybe change the title to "fitting AE92 GZE box to AE82??? need help"
maybe ppl aint reading it?
GZE-STYLE
Camden
Re: how do u do it Sat, 23 August 2003 09:11 Go to previous messageGo to next message
You do know that if you fit a gze box to a 4age will have no performance gain? The ratio's are completely wrong for the 4age. Though if you still want to go ahead with it, are gearbox crossmember mounts arnt lining up propely?
tin can
Re: ae92 4agze lsd gearbox in to a ae82 pls help Sat, 23 August 2003 13:21 Go to previous messageGo to next message
gze-style ive got a 4agze and a gze box lsd out of ae92 coz im going turbo i want two wheels not one so how do i fix the prob of the member mounts not lining up thanks for ur help coz box not in yet so thats one prob solved
Johnny
Sydney, OZ
Re: ae92 4agze lsd gearbox in to a ae82 pls help Sat, 23 August 2003 13:46 Go to previous messageGo to next message
Are you handy with a welder? the GZE mount's will sit completely to the side of the x-member. So either make a new mount or modify what you've got in the way of mounts available, or modify the x-member.
tin can
Re: ae92 4agze lsd gearbox in to a ae82 pls help Sat, 23 August 2003 14:21 Go to previous messageGo to next message
damn souds bloody hard sorry to ask this johnny but if ur lokking in the engine bay what side do the mounts sit on and have u done it before so u could give us pointers on what kind of mounts to make thanks for the help
Johnny
Sydney, OZ
Re: ae92 4agze lsd gearbox in to a ae82 pls help Sat, 23 August 2003 14:43 Go to previous messageGo to next message
from memory, the AE82's (when looking from the front) is offset to the right and the AE92's is offset to the left. I haven't place the GZE box in and AE82 yet, only my AE102, but I have fitted a couple of AE92 and 20V boxes into these Both are the same, different ratios and they are a drama, especially first time! last time I spaced the mount out and it's going ok so far... I think this is the main reason many people run the standard boxes. The only way to really know exactly whats involve is to pull the one you've got out, have the top mounts done up, and start measuring the lower mounts and start modifying, that's the only way... sorry Confused but that's the only way to do it Sad
Twinky
N.S.W
Re: ae92 4agze lsd gearbox in to a ae82 pls help Sat, 23 August 2003 16:02 Go to previous messageGo to next message
Bit of mucking round but it will work.
I did what Mikey pretty much did and it worked a treat.
RHS Mount - Use standard 4age mount.
LHS Mount - You use the standard 4age mount and the mounting bracket. The 4age bracket holes dont line up with the 3 on the gze box, however 2 will. Bolt it to those 2. Then weld a new plate on for the third hole. Now these holes have to be elongated so that the motor is pushed back a fraction towards the back of the car. This will give you the adjustment to get the clearence for the drive shafts, so they dont hit the body.
FRONT MOUNT - Take the standard GE bracket off the back of the standard GE box. Turn it upside down and bolt it on the front of the gze box. Holes will need to be elongated abit to get adjustment. USe the standard GE mount on the cross member, holes again will need to be ellongated for fine adjustment. I cant remeber which way it has to go. NO SPACER IS REQUIRED AT THE FRONT WHERE THE CROSS MEMBER BOLTS. JUST BOLT IT UP HOW IT IS STANDARD.
REAR MOUNT - This is the tricky bit. You use the standard GE Mount and the GZE bracket. The mount holes on the cross member have to be moved back about 2cm. One hole is easy to do the other takes abit of mucking around. Cause you have to drill a small hole for the bolt and then on the other side a bigger one so a socket can go in, bit hard to explain. Once this is done you need to put a spacer to the desired width. Desired width being that you like the gap between the drive shafts and body and also the angle of the motor, i think my spacer ended up being about 30mm which isnt to bad.
I hope this helps. I hope i havnet left anything out. I can get some pics if you like, To show you the cross member.
tin can
Re: ae92 4agze lsd gearbox in to a ae82 pls help Sun, 24 August 2003 00:36 Go to previous messageGo to next message
twinky ur in camden im in hoxton park not that far yes pls send the pics i need all the info i caan get my hands on
Twinky
N.S.W
Re: ae92 4agze lsd gearbox in to a ae82 pls help Sun, 24 August 2003 01:36 Go to previous messageGo to next message
I got the pics. Ur best bet is to get msn or icq so I can send them to you and explain 1 by 1.
msn - trd_twinky@hotmail.com
icq - 67822768.
or I can email them. If so whats your email?
AE82-GZE
Wallerawang
Re: ae92 4agze lsd gearbox in to a ae82 pls help Fri, 19 March 2004 09:36 Go to previous messageGo to next message
Hay TWINKY,
I just read this post you participated in a while back,
you posted some really good info on the 4AGZE to AE82
conversion regarding the engine and box mounts....
You also said you could send some pics of the modified
mounts and so on. I'm just wondering if you still have them
and if you could send them on to me ???
You can contact me on either MSN ofnaob4@hotmail.com or
normal Email trippen@lisp.com.au either is fine by me...
I've added your MSN address to my MSN so you can either just
accept or deny it as you please....
Your help on this will be much appreciated as I'm just starting
this conversion and I'm after all the help I can get...
Thanks heaps
GreyWolfe
Wollongong, NSW
Re: ae92 4agze lsd gearbox in to a ae82 pls help Fri, 19 March 2004 09:57 Go to previous message
I want that damn lsd gearbox Razz
Previous Topic:MA61 Caliper
Next Topic:Advice On Seats
Current Time: Mon Oct 26 07:37:50 UTC 2026
Total time taken to generate the page: 0.14498400688171 seconds
