Toymods » Tech & Conversions » 3TGTE -> AE86 Sprinter
kingpin
Wollongong
3TGTE -> AE86 Sprinter Tue, 19 August 2003 10:21 Go to next message
hi everyone... just wondering how easy it is to have a 3tgte put into the sprinter as a friend of mine is selling one and im wondering if they are that bad to put in
also has anyone here done this?
EVOSTi
cambo
      no
Re: 3TGTE -> AE86 Sprinter Tue, 19 August 2003 11:13 Go to previous messageGo to next message
dunno how hard it is to do but ive seen one in a sprinter bout a couple of months ago. the person wasnt affiliated with toymods AFAIK. personally i wouldnt take that path myself cause im not the biggest 3T fan, but people here seem to rave about them Smile
i think you would be much better off with a 4A series engine.
Re: 3TGTE -> AE86 Sprinter Tue, 19 August 2003 11:15 Go to previous messageGo to next message
Plenty of power can be had on the cheap with a 3T-GTE, and the fact they're turbo from the factory is a big bonus over a 4A. Go for it I say!
horner boy
Re: 3TGTE -> AE86 Sprinter Tue, 19 August 2003 23:43 Go to previous messageGo to next message
Are they more difficult to fit than a 4agze?
Necros
Re: 3TGTE -> AE86 Sprinter Wed, 20 August 2003 01:04 Go to previous messageGo to next message
You will most likely need to fab engine mounts and get an engineers certificate because its not from the same family of engine as the 4a(c,ge,gze).
And a 4agze would be much easier to 'bolt' in.
Re: 3TGTE -> AE86 Sprinter Wed, 20 August 2003 01:32 Go to previous messageGo to next message
I wouldn't mind betting a T18 crossmember would bolt into an AE86 chassis, which of course is designed for a T series engine.
roger
Re: 3TGTE -> AE86 Sprinter Wed, 20 August 2003 05:31 Go to previous messageGo to next message
I think Norbie may be right the t18 member most likely bolts in but I haven't confirmed it. The problem you have in doing this is the power steering mounts won't be on the t18 member in which case you will have to weld them on. In my opinion the easiest way is to unstich the engine mount off the ae86 member and re weld in the appropriate place. I have looked into this and it looks like a straight forward and a well worth while conversion. Yes the 4agze may look like a cheap and easy conversion but the FWD/RWD looks like buggering around(cooling/intake) to me and when you have to pay delwo automotive 500+ for a bellhousing to get a half decent box behind it, the 3tgt starts to look attrative to me. The engine era is right 83-85 and if using the orignial efi gear ther should be no problem in getting engineers certificate
by the way if you gze any car that is supposed to be NA then an engineering certificate will be required.
[Updated on: Wed, 20 August 2003 05:32]
Necros
Re: 3TGTE -> AE86 Sprinter Wed, 20 August 2003 10:19 Go to previous message
I'd be puttin money on it ;p
Previous Topic:AE86 Weight Loss, What next?
Next Topic:Top Gun Ignition Leads
Current Time: Wed Oct 21 10:00:48 UTC 2026
Total time taken to generate the page: 0.015952110290527 seconds
