Toymods » Tech & Conversions » ke70 to 4age
Lumpyclod
ke70 to 4age Tue, 19 August 2003 12:58 Go to next message
Im lookin at doing an engine conversion to my beloved ke70. It now has 300k km on the standard 4kc engine and i think it is time to retire her to greener fields. Ive been thinkin of swapping a 4age motor from a sprinter into it for years but the damn 4kc wouldnt die haha. So what im asking is a rough price for the hole conversion ? Ive also been searching and found outi will need some parts from an ae71 corolla, is it only the crossmember and engine mounts? What about electrics and the fuel system?
Thanks for you help in advance
Mark
IRA11Y
Club Member
Re: ke70 to 4age Tue, 19 August 2003 19:47 Go to previous message
electrics are easily adapted, and the fuel side will need a high PSI fuel pump and replace the standard rubber at the tank with efi hose and clamps. As far as cost goes that is really dependant on how much you get parts and engine for.
you will need things like fuel filters, engine loom etc and may want to consider getting the injectors serviced if the engine has been sitting for a while, if its an import you may want to replace all belts and seals as well, you can pick up early GE's for relatively cheaply as a whole package, and there are people at various clubs upgrading to GZE or 100Kw so finding them isnt too hard.
on top of the cross member you will also need the engine to gearbox supports at the bottom of the engine
Previous Topic:RT-142 live axle question - using in RA2*
Next Topic:ae-92/93 HANDBRAKE ADJUSTMENT
Current Time: Fri Oct 23 03:55:56 UTC 2026
Total time taken to generate the page: 0.0049569606781006 seconds
