Toymods » Tech & Conversions » Spark Plugs (code)
ta2272
icon2.gif  Spark Plugs (code) Wed, 20 August 2003 04:12 Go to next message
what sort of spark plugs fit the 2tg head, i have to get some. thanks
Jason
gmsta27
Fl
Re: Spark Plugs (code) Thu, 21 August 2003 02:51 Go to previous messageGo to next message
manual calls for bp6es ngk I use bp5es ngk in mine the car would load up at idle and around town with the 6's.
Greg
ta2272
Re: Spark Plugs (code) Thu, 21 August 2003 09:21 Go to previous messageGo to next message
i bought bp5ey it said that they suit the 2t motor (i have a 2tg) these will be ok wont they.
Jason
Re: Spark Plugs (code) Thu, 21 August 2003 14:32 Go to previous messageGo to next message
yup. the B P and E refer to the thread size and reach and nose type.
the 5 and 6 are the heat range. 5 is good for normal tootling, but 6 is better if you drive hard often.
the S is standard electrode, Y is v-groove.
check the BP5EY after a hard drive, see what colour they are.. if they are discolouring from being too hot, then go for 6's
btw, how much you pay for them Wink
ta2272
Re: Spark Plugs (code) Sat, 23 August 2003 03:06 Go to previous messageGo to next message
i bought them in a pack of four for like 13 $ should i upgrade to the ^'s will this help me with power etc? much
Jason
Re: Spark Plugs (code) Sat, 23 August 2003 03:13 Go to previous message
it depends on how you drive really. spark plugs work best in a certain temperature range (all plugs) and the different heat range plugs conduct heat away from the electrodes at different rates to maintain that temperature (ie 'colder plugs' conduct heat away faster)
if you drive normally, then 5's may be ok, but if you are a bit spirited, then the 5's may get too hot... try them and inspect periodically.... colder plugs are better for more aggressive driving where you will be at WOT more often, but are more likely to foul at idle for long periods...
if you find the cold plugs always black, evebn after a fang, then they are too cold (or your mixture is too rich), but if they are clean with a nice colour, are not too cold. if they look overheated, then are too hot...
hard to explain without pics, and dificult even then .... hmmmm
anyhoo, see how the 5's go.
Previous Topic:upgrading my rims...
Next Topic:Corona brakes
Current Time: Thu Nov 19 14:40:32 UTC 2026
Total time taken to generate the page: 0.016326904296875 seconds
