Toymods » Tech & Conversions » Coilovers on RA2x
Coilovers on RA2x Wed, 20 August 2003 07:09 Go to next message
Hi all, well i'm seriously considering changing the front shocks on the RA28 to coilovers.
I know some of this has been covered before but just wanted to run it again so i'm confident on what i'm actually purchasing/doing.
The plan is to use the original Corona XT130 struts(I put these struts in when changing to the 4 spot calipers, pug discs etc).
I plan to cut off the original lower perch(I hope thats the right name for it.. Where the spring sits anyway), and then shorten the strut by 60mm or so.
Reason for shortening is I wanted to run the AE92 corolla inserts, which have a shorter stroke which is achieved by a shorter body length and also stroke. My understanding is the body is 60mm shorter than original RA28 items. But I would confirm this before cutting!
I am thinking Koni yellow AE92 inserts.
Whiteline have a kit that comes with top cap, threaded sleeve, height adjust screw and locking screw.
Weld the threaded sleeve onto the original shock.
Put some springs on (anyone suggest what weights etc are good to go for?) and some adjustable strut tops for camber adjustment.
What does everyone think?
Also on a side note... I'd like to hear what suspension setups everyone else is running on their RAs.
Mine so far is :
Whiteline adjustable front sway bar
Pedders sports rider all round
1 inch lowered king springs all round
18mm rear non-adjustable shelby swaybar
Joel
[Updated on: Wed, 20 August 2003 07:12]
Jason
Re: Coilovers on RA2x Wed, 20 August 2003 07:43 Go to previous messageGo to next message
Im still working on mine,
xt130 struts with std brakes lowered springs about 3/4 of an inch 25-27mm front sway bar, new bushes throughout adjustable lower control arms with modified crossmember.
Rear is basically the same minus the sway bar which i removed the other day and an adjustable panhard rod on the way.
DJ345
eastern suburbs, Melb
Re: Coilovers on RA2x Wed, 20 August 2003 08:37 Go to previous messageGo to next message
G'day was just wondering what the part number for the white line coil over kit.
Thanks Damian
Re: Coilovers on RA2x Wed, 20 August 2003 10:21 Go to previous messageGo to next message
also what kind of cost they are??? there was some coilover thing smentioned before in regards to AE86, which were around $200 a set...
i'm also wanting to do the same, shorten the strut etc...
Re: Coilovers on RA2x Wed, 20 August 2003 10:35 Go to previous messageGo to next message
Around $120 per side for the coilover gear.
Around $300 for each koni yellow shock insert!! Thats the killer.
Jayem
Finland
Re: Coilovers on RA2x Thu, 21 August 2003 18:46 Go to previous messageGo to next message
I did coil-over setup for TT-132 struts and I can tell you that if you shorten your struts 60mm you will end up with way too low setup, 40mm is fine. I turned in lathe 20mm nylon spacer, its now in the bottom of the strut. AE-92 shock has 60mm shorter body and 40mm shorter stroke than *T-13* one.
Shocks...
http://www.garagedori.com/tech/shocks.html
Conversion and info...
http://www.club4ag.com/faq%20and%20tech_pages/Shor t%20Stroke%20Conversion.htm
hiaaa
Re: Coilovers on RA2x Fri, 22 August 2003 07:43 Go to previous messageGo to next message
I shorten mine for 40mm and use 20mm spacer too, and that's low enough. I can send you some pic if you want.
Leon
EMP-2TG
Carlingford, Sydney
Re: Coilovers on RA2x Fri, 22 August 2003 10:15 Go to previous messageGo to next message
mine are very similar to hiaaa's but im using camary inserts and 300lb/inch king springs
they work very well i feel
blackRA28
adelaide
Re: Coilovers on RA2x Sat, 23 August 2003 03:03 Go to previous messageGo to next message
TurboRA28 wrote on Wed, 20 August 2003 16:39
Mine so far is :
Hey Joel,
Yeh I am running quite a similar setup to you actually!
Whiteline/selby front 24mm swaybar
Whiteline/selby rear 18mm swaybar (both non-adjustable types, with Noltec bushings)
1&1/2" lowered king springs all round
KYB red shocks all round
It is quite a firm setup and gives plenty of response, but i have yet to find out what it handles like with both swaybars, as they have been added while the car is off the road, but none the less i am happy with how she handled without the two swaybars so hopefully it should improve even more..
this is quite an interesting post, id like to hear/see how well it works with the ra28 and the handling characteristics after doing such a mod..
Good luck
Guy
Re: Coilovers on RA2x Sat, 23 August 2003 07:14 Go to previous messageGo to next message
Hiaaa - would like to see some pics mate, thanks! sounds like 40mm in strut and 20mm spacer is the way to go for sure.
Anyone used GT4 inserts?
I'll keep everyone posted with the progress of it. Seems the hardware for the coilovers is cheap enough, but the koni yellows cost an arm and a leg.
Joel
hiaaa
Re: Coilovers on RA2x Sat, 23 August 2003 08:48 Go to previous messageGo to next message
Here's some pic of mine:
http://homepages.ihug.com.au/~turbo86/photo/coil_o ver/
Leon
DJ345
Re: Coilovers on RA2x Sat, 23 August 2003 16:01 Go to previous messageGo to next message
hiaaa are the rca's custom made or of the shelf items? have you got the part numbers for these and the coil overs.?
EMP-2TG
Carlingford, Sydney
Re: Coilovers on RA2x Sat, 23 August 2003 17:14 Go to previous messageGo to next message
go to www.ae86world.com
this is where i got some of my stuff from
and if your a toymods member u can get the coil over bits for $170/pair i think (not from ae86world)
hiaaa
Re: Coilovers on RA2x Sat, 23 August 2003 22:41 Go to previous messageGo to next message
I got my coil over kit from John (ae86world) too, but not the RCAs. John was going to get few set RCA make but no one has ask for one so far.
Leon
EMP-2TG
Carlingford, Sydney
Re: Coilovers on RA2x Sun, 24 August 2003 02:21 Go to previous messageGo to next message
try pitwater brake and clutch for some good prices to toymods members.. they will be cheaper than 99% of places
Re: Coilovers on RA2x Sun, 24 August 2003 05:37 Go to previous messageGo to next message
Hiaaa - mate thanks for the pics this is just want i'm looking at doing!
Do you have any contact details for ae86world? their website seems to be stuffed.
I wanted the ones that you can weld onto the strut.
Joel
Dylo
Re: Coilovers on RA2x Sun, 24 August 2003 09:38 Go to previous messageGo to next message
Hi there i changed my shockies a while back to gas inserts, but is there meant to be some kinda plug like mentioned above that goes in the bottom of the strut so the shockie sits on that, because they are a lil short and seem to rattle round in there!
trent_kershaw
Re: Coilovers on RA2x Sun, 24 August 2003 11:51 Go to previous messageGo to next message
Dylo wrote on Sun, 24 August 2003 19:38
When I bought gas shocks for my car, the left one had that problem too... I solved it by just putting some washers in the bottom of the strut. Smile
purpleminiep
Mentone
Re: Coilovers on RA2x Sun, 24 August 2003 12:34 Go to previous messageGo to next message
Where did you get the neg camber rca's from. How much were they?
Brad
gold28
Madrid - Spain
Re: Coilovers on RA2x Mon, 25 August 2003 03:22 Go to previous messageGo to next message
Hey Leon, thats a really nice looking set up you have, I would be interested to find out the contact details for this John fella from ae86world. I was thinking of doing a similar thing in my car.
EMP-2TG
Carlingford, Sydney
Re: Coilovers on RA2x Mon, 25 August 2003 03:50 Go to previous messageGo to next message
http://www.geocities.com/emp_emp2000/coilovers.txt
here is a pic of the setup in my ke30
they will bolt into most rwd toyotas Smile
Steve_Reynolds
Gold Coast
Re: Coilovers on RA2x Mon, 25 August 2003 03:59 Go to previous messageGo to next message
I have fitted Holden Camira insterts into my coilovers. They are shorter and come in koni yellow's also.
Re: Coilovers on RA2x Mon, 25 August 2003 04:07 Go to previous messageGo to next message
Looks nice Josh, where did you get your bits n pieces from?
Joel
EMP-2TG
Carlingford, Sydney
Re: Coilovers on RA2x Mon, 25 August 2003 04:15 Go to previous message
i got the coil over bits ($230) from ae86world.com
but u can get them from pittwater brake and clutch cheaper
the springs ($180) i just got from 1 of the local joints in taree and same with the shocks ($95)
i just went thru the parts catalouge till we found shocks that would do the job and they work well
i think it cost about $60 all up toget the old spring mount machined off and then cut 40mm shorter on the lath, and then all tig'd back up
i still got abit of tweaking to do with my setup
but it is working well Smile
Previous Topic:new hilux
Next Topic:Z2 Full Stereo Installation Help
Current Time: Fri Oct 23 15:18:09 UTC 2026
Total time taken to generate the page: 0.0060811042785645 seconds
