Toymods » Tech & Conversions » Where does this pipe goto
Hypo
Where does this pipe goto Wed, 20 August 2003 10:52 Go to next message
On a 20val where does this pipe goto.
http://members.dodo.com.au/~bmb/20val.jpg
Thanks for your help
Seadog
Re: Where does this pipe goto Wed, 20 August 2003 12:47 Go to previous messageGo to next message
Hmmm. I think all those pipes in that area just take manifold vacuum, so probably something that needs that, like brakebooster or something (although I think that is the bigger one on the ISCV). On mine it is just plugged and I only bought a motor not a front cut so the original pipe was just cut. Sorry I can't help you more.
Scorpion
Menai area of Sydney
Re: Where does this pipe goto Wed, 20 August 2003 13:28 Go to previous messageGo to next message
On EvilJack's 20v it goes to a valve mounted on the firewall and then back into the rubber air intake between the AFM and the throttle body plenum ? There is an electrical switch on the side of the valve mechanism to activate it, but I don't know at this time what triggers the switch to open or to close. From your picture it looks like yours is doing the same thing.
sideshow
Re: Where does this pipe goto Wed, 20 August 2003 22:35 Go to previous messageGo to next message
if it goes to a valve on the firewall then its the air conditioning idle up valve
if u have no a/c then just plug the pipe or fit a ball bearing inside it and connect it to the corresponding spot on the intake pipe just after the air flow meter
Hypo
Re: Where does this pipe goto Thu, 21 August 2003 07:19 Go to previous message
Thanks for your help.
Anyone know how long before the idle will settle down
Previous Topic:Whiteline or Koni
Next Topic:3SGE model interchangability?
Current Time: Thu Oct 29 18:53:54 UTC 2026
Total time taken to generate the page: 0.0047788619995117 seconds
