Toymods » Tech & Conversions » What are the signs of stuffed turbos?
RA231G-GTE
melb eastern subs
icon5.gif  What are the signs of stuffed turbos? Wed, 20 August 2003 14:18 Go to next message
Confused Just wondering how can i tell if my turbos r stuffed?
Im gettn a bit of black smoke when i boot it and have noticed a power decrease, but can still hear turbos spooling and i still get boost pressure out of blow of valve?
Re: What are the signs of stuffed turbos? Wed, 20 August 2003 23:19 Go to previous messageGo to next message
Black smoke means fuel, ie your engine is running super-rich for some reason. This would explain your power loss, and you'll probably find your plugs are nicely fouled by now as well. You'd better find out what's causing it!
CLG
Perth, Western Australia
Re: What are the signs of stuffed turbos? Wed, 20 August 2003 23:55 Go to previous messageGo to next message
White oil smoke and lots of it!!! Sometimes it also has a sickly sweet smell to it. The smoke can come from either boost or liftoff, with a quick physical check of the turbo not always showing signs of wear in the shaft.
Agree with Norbie on the BLack smoke-running rich issue too! Pull your sensors (ie idle bypass, fuel enrichment, ...) check that they aren't gummed up and seized, if they are try a good form of carbie cleaner (I only try to use CRC - they carry more active ingredient)to clean them. If you're running an AFM, this could also be the culprit, with the spring needing more tension too.
Re: What are the signs of stuffed turbos? Thu, 21 August 2003 00:20 Go to previous messageGo to next message
The most common cause of running rich on a turbo engine is a post-turbo air leak. Check your inlet hoses and pipes and make sure everything's securely attached.
RA231G-GTE
melb eastern subs
Re: What are the signs of stuffed turbos? Thu, 21 August 2003 04:13 Go to previous messageGo to next message
Thanx guys will check your advise out i should find out what the prob is.
crazy_camry
Re: What are the signs of stuffed turbos? Thu, 21 August 2003 09:01 Go to previous messageGo to next message
any more info on checking if tourbo is alright, the one i have has what looks like oil burnt onto on the compressor blades, plus there was a little oil in the housing, the seals are busted right? what else should i look for?
Re: What are the signs of stuffed turbos? Thu, 21 August 2003 09:04 Go to previous messageGo to next message
Check for play in the shaft, both radially and axially; there should be pretty much none. Even half a millimetre of play can mean the turbo is stuffed.
RA231G-GTE
melb eastern subs
Re: What are the signs of stuffed turbos? Fri, 22 August 2003 04:55 Go to previous messageGo to next message
is there a manual for the 1ggte?as i don't know much about this engine and am learning as i go when i have problems,what do these engine sensors look like and where are they situated on this engine?anyone have any pics?any help would be great.
HedgehogSandwich
UK
Re: What are the signs of stuffed turbos? Fri, 22 August 2003 11:44 Go to previous messageGo to next message
classic early turbo seal failure symptom is wispy smoke on tickover after a run (eg sitting st at traffic lights).... normally takes 30sec to a couple of minutes to appear.
dispatcher
Malaysia,Kuala Lumpur
Re: What are the signs of stuffed turbos? Sat, 23 August 2003 00:44 Go to previous messageGo to next message
Hedge, is the 1G TT popular in the UK ??
Bugman
Re: What are the signs of stuffed turbos? Sat, 23 August 2003 05:51 Go to previous messageGo to next message
yeah combining both your erreatic idle and your black smoke I'd say it'd have to be a air leak...
HedgehogSandwich
UK
Re: What are the signs of stuffed turbos? Sat, 23 August 2003 10:56 Go to previous message
dispatcher wrote on Sat, 23 August 2003 01:44
nope..probbably less over here than the 2.5tt, of which theres only a handful.
Previous Topic:Boosting 1G-GTE
Next Topic:3S-FE --> 3S-GE Swap
Current Time: Tue Oct 27 13:04:48 UTC 2026
Total time taken to generate the page: 0.053411960601807 seconds
