Toymods » Tech & Conversions » 3SGTE- loss of hp.
CS3086
Denmark
3SGTE- loss of hp. Wed, 20 August 2003 20:15 Go to next message
Hey.
If I have driven very hard and the engine is very hot i got problems with loss of HP. when i step on it. The pressure is 0.9 bar and I have dismantlet the hose from the actuator to the vsv Fuel-cut)and closed it with a bolt. I don´t have the shield over the turbo either could it be hot air = hp loss?
Any ideas?
Jacob -Denmark-
MR. 2
Parramatta
Re: 3SGTE- loss of hp. Wed, 20 August 2003 22:23 Go to previous messageGo to next message
they have a boost cut on them if within the ecu, if it gets too hot it will ristrict the boost to about 6 - 8 psi rather then the std 10psi....
CS3086
Denmark
Re: 3SGTE- loss of hp. Thu, 21 August 2003 05:14 Go to previous messageGo to next message
Hey.
Yes that I know but the boost don´t drop it´s constant on 0.9 bar, It don´t care if I take the pedal to the metal it seem´s that i have loss 50hp.?
Jacob
Nark
Cabramatta, NSW
      Nark@toymods.net/Work
Re: 3SGTE- loss of hp. Thu, 21 August 2003 05:31 Go to previous messageGo to next message
If the boost doesn't change, but you're feeling a loss of power, it could be the knock sensor pulling things back.
0.9bar is not factory boost is it? It's pretty high if it is!
Are you using the standard intercooler?
CS3086
Denmark
Re: 3SGTE- loss of hp. Thu, 21 August 2003 16:12 Go to previous messageGo to next message
Hey.
No it´s not standard, the standard boost is 0.65bar and yes I am using the standard watercooled intercooler.
Knocksensor? would it not do it also when cold? (or not so hot)
Nark
Cabramatta, NSW
Re: 3SGTE- loss of hp. Thu, 21 August 2003 23:28 Go to previous messageGo to next message
Because when the engine is hot, there's more chance of detonation occurring, which means the knock sensor will step in and pull everything back.
CS3086
Denmark
Re: 3SGTE- loss of hp. Fri, 22 August 2003 14:33 Go to previous messageGo to next message
okay here is the trickey one, if I loosen the throttle a bit in a minut or so and then give it full throttle there is nothing wrong with it but then it suddenly appears again if I have gone fast for a time.?
(Sorry for my bad english) Confused
Jacob
Nark
Cabramatta, NSW
Re: 3SGTE- loss of hp. Mon, 25 August 2003 00:29 Go to previous message
That'd prolly mean that your engine is getting hot...
Do you have an a/a intercooler or w/a? If it's w/a, your pump might have stopped working so your intercooler has turned into an interwarmer...
Previous Topic:7MGTTTTE
Next Topic:Crossmember/Chassis spacers
Current Time: Thu Oct 22 18:54:59 UTC 2026
Total time taken to generate the page: 0.0053200721740723 seconds
