Toymods » Tech & Conversions » Extremely High Fuel Consumption 1GGTE !! Anybody ?
dispatcher
Malaysia,Kuala Lumpur
icon5.gif  Extremely High Fuel Consumption 1GGTE !! Anybody ? Thu, 21 August 2003 02:33 Go to next message
Hello again, have a question on the above, Cressida GX60 converted to 1G-GTE 3rd gen. About 2-3 days ago noticed that the fuel consumption has doubled and i'm getting worried. Here's what's been done.
Stock Engine - Intercooler stock,
BOV , Lightened Flywheel, Stock boost, no electronic extras i.e. SAFC Boost controller etc.
Things i've noticed - SOMETIMES puff of white smoke when i start,othertimes ok. There's are a a few more sockest and wires that need to be connected (3-4 maybe). And when i try to floor it..SOMETIMES..feels like there's fuel starvation occuring..struggles then the boost comes on..LAG then WRoooom..
Even in normal SUNDAY drivers condition...still seems pretty high ?...Could a leak in the piping/intercooler be the cause..
OH also my exhaust is 3 inch all the way..with a 3inch muffler at the end. NO centre resonators.
Any feedback greatly appreciated.
[Updated on: Thu, 21 August 2003 04:32]
Stenno
Re: Extremely High Fuel Consumption 1GGTE !! Anybody ? Thu, 21 August 2003 05:56 Go to previous messageGo to next message
Did the problem start after you installed the BOV?
[Updated on: Thu, 21 August 2003 05:57]
dispatcher
Re: Extremely High Fuel Consumption 1GGTE !! Anybody ? Thu, 21 August 2003 06:03 Go to previous messageGo to next message
Nope, BOV was off the engine itself from the half cut. SO just swapped everything..from the half cut to my cressie. Was running fine until 2 days ago.
Re: Extremely High Fuel Consumption 1GGTE !! Anybody ? Thu, 21 August 2003 06:25 Go to previous messageGo to next message
that "fuel starvation" problem you're describing could also be caused by it boggin down under too much fuel, which would also explain the massive fuel usage.
also, a 3" exhaust all the way thru will mean you're actually running higher than stock boost
dispatcher
Re: Extremely High Fuel Consumption 1GGTE !! Anybody ? Thu, 21 August 2003 07:53 Go to previous messageGo to next message
What should i do then ? , Also noticed another thing, as i floor the pedal and the boost just kicks in..there's a sort of a 'tug' just a second..and than evens out.
Danish
Re: Extremely High Fuel Consumption 1GGTE !! Anybody ? Thu, 21 August 2003 08:26 Go to previous messageGo to next message
This is what happened to my old 1G-GTEU, white smoke on start up that eventually went away after driving, then few months later same white smoke on start up then poured out smoke on acceleration. Turned out to have low compression, massive amount of lag, and oil throughout the intake.
I cut the engine loose and put a 1JZ in it. It is fixable though.
dispatcher
Re: Extremely High Fuel Consumption 1GGTE !! Anybody ? Fri, 22 August 2003 03:05 Go to previous messageGo to next message
The oil in the intake i suppose the oil catch will take care of that. Yesterday i pulled the fuse for the ECU, and after a while i started and the motor wound up and then started to 'readjust' itself with the fluctuating RPM higggg.lowwww until it settlesd.
Last night tried again. seemed to have temporarily solved the prob..but will have to wait and see.
RA231G-GTE
melb eastern subs
Re: Extremely High Fuel Consumption 1GGTE !! Anybody ? Fri, 22 August 2003 05:10 Go to previous messageGo to next message
i have simaler simptons,i got the white smoke,oil in intake,but seems to be ok on fuel though,i had low compression in one of the cylinders got a new headgasket mech said it seemed to have brought the compression back up, but this was before all of this smoke and oil started,i also get on start up it revs high and drops down low and it goes up and down up and down until the engines warm also the engine is runnin mega rich with fuel smell coming from the white smoke.
dispatcher
Re: Extremely High Fuel Consumption 1GGTE !! Anybody ? Sat, 23 August 2003 00:39 Go to previous messageGo to next message
I wonder if adjusting the Co would help ?...But like i mentioned earlier...resetting the ECU seems to have helped.
Dylo
Re: Extremely High Fuel Consumption 1GGTE !! Anybody ? Sun, 24 August 2003 09:58 Go to previous message
I used to get that up/down idle and then it would even out. it used to do it after every time u touched the acc. and let it go back to idle.
Turned out to be low fuel press. Now it runs SWEET!
Previous Topic:help with hooking up a Speco tacho onto a 4A-C power Tercel
Next Topic:Brake Bias Adjustment
Current Time: Fri Oct 23 23:59:35 UTC 2026
Total time taken to generate the page: 0.0053410530090332 seconds
