Toymods » Tech & Conversions » Cold Air Feed. WHAT IS IT ?
dispatcher
Malaysia,Kuala Lumpur
Cold Air Feed. WHAT IS IT ? Thu, 21 August 2003 03:06 Go to next message
What is this contraption ? Cold air feed (from Where) ??
Danners
Central Coast, NSW
Re: Cold Air Feed. WHAT IS IT ? Thu, 21 August 2003 03:09 Go to previous messageGo to next message
cold air feed is when you get some kind of tubing from the front of your car and guide it up to your air intake so that the air filter is no longer sucking in hot air produced by your engine
most people put some kind of aluminium shielding around the air filter to eliminate the hot air getting in as well
Dan
dispatcher
Re: Cold Air Feed. WHAT IS IT ? Thu, 21 August 2003 04:24 Go to previous messageGo to next message
Dan, would it be wise to shroud the filter with some kinda material and have an intake leading to it say from the front end of the car, clear of debri or water ??
Danners
Central Coast, NSW
Re: Cold Air Feed. WHAT IS IT ? Thu, 21 August 2003 05:23 Go to previous messageGo to next message
definitely! the colder the better Very Happy
Simon-AE86
Banned user
ADELAIDE - The Drift City
Re: Cold Air Feed. WHAT IS IT ? Thu, 21 August 2003 05:32 Go to previous messageGo to next message
mine consists of alum sheeting surrounding the pod filter and sealing when the bonnet is closed.. cold air gets fed from around the headlight
dispatcher
Re: Cold Air Feed. WHAT IS IT ? Thu, 21 August 2003 06:06 Go to previous messageGo to next message
Was thinking of the same thing. My filter is just behind the right H/lamp assy. Will give it a go.
DVS_ONE
Re: Cold Air Feed. WHAT IS IT ? Fri, 22 August 2003 02:48 Go to previous messageGo to next message
i have a front mount cooler Very Happy
kyler
Re: Cold Air Feed. WHAT IS IT ? Fri, 22 August 2003 03:03 Go to previous messageGo to next message
Can someone confirm to me if this feed has to be protected form water? I mean, wouldn't water easily get sucked up the intake during rain etc?
dispatcher
Re: Cold Air Feed. WHAT IS IT ? Fri, 22 August 2003 03:15 Go to previous messageGo to next message
I'm pretty sure water is a NO NO !!
Rolling Eyes
MR. 2
Parramatta
Re: Cold Air Feed. WHAT IS IT ? Fri, 22 August 2003 03:22 Go to previous messageGo to next message
its not a good thing but a tiny little bit of water never hurt a motor... i have an mr2 and when i rains i am garanteed to get water into the intake , as i have my filter sitting snug in one of the vents... so yup i get water my motor still is stong and no probs with starting it etc etc...
Re: Cold Air Feed. WHAT IS IT ? Fri, 22 August 2003 03:34 Go to previous messageGo to next message
heh heh, cheap water injection when it rains Wink
since when fuel is burnt, it produces heaps of water, a bit of water going in won't hurt anything. it's a problem if it then sits in places like carbs or throttle body, or manifold and causes corrosion, or if there is LOTS of water being sucked in.
maybe have the intake sligtly obstructd so that at highway speed, rain is not picked up thru the duct. (and not so close to the road either)
Re: Cold Air Feed. WHAT IS IT ? Fri, 22 August 2003 03:39 Go to previous messageGo to next message
Your inlet duct would have to be completely submerged in water before water consumption became a problem. The amount of water ingested due to rain, even at highway speeds, is negligible compared to the volume of air being ingested. So don't try any river crossings, but apart from that there's no need to worry! Smile
gmsta27
Fl
Re: Cold Air Feed. WHAT IS IT ? Fri, 22 August 2003 17:38 Go to previous messageGo to next message
Used to clean the carbon off the valves of a 2.6 liter capri by pouring a glass of cold water down the carb with the motor running. just go to full throttle while pouring the water in to the carb.
dispatcher
Re: Cold Air Feed. WHAT IS IT ? Sat, 23 August 2003 00:36 Go to previous message
Now that something you don't hear everyday, Water in the Carbies..cleaning carbon..hmm....might have to try that.
Previous Topic:Corona brakes
Next Topic:Strut Brace Spacers
Current Time: Sun Nov 22 21:37:59 UTC 2026
Total time taken to generate the page: 0.0046951770782471 seconds
