Toymods » Tech & Conversions » test lights?
RA231G-GTE
melb eastern subs
icon5.gif  test lights? Thu, 21 August 2003 04:18 Go to next message
i had a test light installed when i had conversion wired up i think its for codes for the sensors on the engine?Anyway after i drive the car for around 15min it just stays on what could this be?Could a sensor hav failed?its been doing this since i got it wired up and the auto elec who done the job cant figure it out either? Confused
rob_RA40
c'town, NSW
Re: test lights? Thu, 21 August 2003 04:37 Go to previous messageGo to next message
that is the engine check light telling u to check the error codes.
usually with a 1G conversion there will be something thats not needed or not hooked up, eg. air con, or speed signal from auto gearbox etc. if EVERYTHING was hooked up then there is a possible problem with some part of the engine.
there should be a little black box in your engine bay marked (if i recall correctly) 'diagnosis' u have to jumper 2 terminals and then the little light will flash u a code in a sequence of flashes.
check out this section for engine manuals, the 7M and 4A have similar error code tables.
EDIT: i disconnected my engine check light as my air con isnt hooked up and it stays on all the time. Now each time i service the car i check the error codes then disconnect the light again.
[Updated on: Thu, 21 August 2003 04:40]
RA231G-GTE
melb eastern subs
icon12.gif  Re: test lights? Thu, 21 August 2003 04:49 Go to previous message
yeah i dont have air con and a few other things hooked up, that must be it then thanx for the help. Cool
Previous Topic:..::taking out a ae92 dash cluster::..
Next Topic:Wing mirrors... TA/RA serries Celica
Current Time: Sun Nov 1 10:15:02 UTC 2026
Total time taken to generate the page: 0.05164098739624 seconds
