Toymods » Tech & Conversions » hard to start ma61
STR8 2.8
hard to start ma61 Thu, 21 August 2003 08:05 Go to next message
my ma61 takes a while to get going
it always starts,
but it requires me to crank it over for a while, it doesnt just start up after a few cranks
is this just the norm for old cars, and just forget about it?
is there anything i can do, replace something to make it good?
i dont really care that much and not really worth spending much on, its just annoying, thats all.
coronamark2
Re: hard to start ma61 Thu, 21 August 2003 08:15 Go to previous messageGo to next message
if it goes reeee-reeeeeee-reeeeeBRUMMM( Embarassed lame noises) its your starter motor, And if your batterys old and crusty it might be that.
but my starter motor cost $200 for a recond one so??
keep crankin
ZZT231
melbourne.vic.au
Re: hard to start ma61 Thu, 21 August 2003 08:29 Go to previous messageGo to next message
I don't know if the 5M-E isn't fitted with a fuel regulator on the fuel rail but if it is fitted with one, that may be your trouble since the petrol is going back into the tank after at rest (happened to a friends VN V6).
Or if it cold, is your Air Bypass Valve working properly? Had a cranking problem in the mornings and couldn't idle properly and found out it was the valve...
Hope it helps.
Cheers.
STR8 2.8
Re: hard to start ma61 Thu, 21 August 2003 10:39 Go to previous messageGo to next message
its not the starter, replaced that recently $300 new
doest make any funny noises, just takes a number of cranks to get it going
battery is fine, tested that not long ago when i couldnt start it (starter)
wilbo666
Re: hard to start ma61 Thu, 21 August 2003 11:04 Go to previous messageGo to next message
Yeah I'm betting on a stuffed ABV....
Am I right in thinking that it starts fine after its been run for a bit, or does it do it all the time? (If so it sounds like the ABV)
STR8 2.8
Re: hard to start ma61 Thu, 21 August 2003 11:13 Go to previous messageGo to next message
correct wilbo
once its warm its starts no worries
ma61_turbo
Re: hard to start ma61 Thu, 21 August 2003 11:48 Go to previous messageGo to next message
Clogged cold start injector? Or could just be not working...
Personally I prefer it to crank a few times before it fires, gives time for oil to be sent up to the cam etc. I've actually disconnected the CSI on my 7m-gte so it does this.
New cars seem to do this as standard these days. My dad's vr commo is like this and so is my gf's my99 wrx. Cranks 2-3 times before it fires up.
STR8 2.8
Re: hard to start ma61 Thu, 21 August 2003 12:38 Go to previous messageGo to next message
CSI..
i thought it might have been something like that, but i dunno
2-3 times, well mine cranks like 10-15 times before it starts.
[Updated on: Thu, 21 August 2003 12:38]
ma61_turbo
Re: hard to start ma61 Thu, 21 August 2003 13:57 Go to previous messageGo to next message
Could be a combination I guess. Worth checking it all out anyway.. Dunno how easy it would be to get to the CSI, the 7m one is a pain in the arse to get to Wink
wilbo666
Re: hard to start ma61 Thu, 21 August 2003 14:03 Go to previous messageGo to next message
Yeah, my CS injector was pretty stuffed, its an easy job to see if its clogged by the way, rip it out of the inlet manifold (its only two screws) and plug the manifold with a rag etc. Then place the injector so it sprays into a jar and get someone to crank the motor over for you, it should spray a fair amount of petrol into the jar in a nice spray, not dribble...
Anyway I replaced mine with one that did work nicely and its still got the same problem.. Sad
Best of luck..
STR8 2.8
Re: hard to start ma61 Fri, 22 August 2003 13:32 Go to previous messageGo to next message
cool thanks guys,
ill have a look at the abv and the csi soon
and also,
haynes manual refers to "air valve", im guessing this is the same as thing the abv (thing above the cam cover with a few hoses coming out of it)
wilbo666
Re: hard to start ma61 Sat, 23 August 2003 01:46 Go to previous messageGo to next message
Yep thats the one
http://members.iinet.net.au/~tigerbeer/ABV.jpg
(sorry for the huge size Embarassed )
ZZT231
melbourne.vic.au
Re: hard to start ma61 Sat, 23 August 2003 05:20 Go to previous messageGo to next message
Hey All,
I said it could have been the Air Bypass Valve as well! Mad
Anyway, Wilbo, how did you get your engine to look clean and shiny as that?
Cheers...
wilbo666
Re: hard to start ma61 Sat, 23 August 2003 05:32 Go to previous messageGo to next message
ZZT231 wrote on Sat, 23 August 2003 15:20
Lol take one boring holiday, add lots of time....!
I knida did it in stages, first I just cleaned the engine bay with degreaser / rag / water, then when it looked clean I started polishing the aluminium stuff with "mother Al and mag polish". Next plan is to do the wheels when I have time Confused
I've had another go at the tappet cover since that pic, but I think I'll need to get a buffing wheel or something else to get it looking much better....(oh yeah I took the tappet cover off and sanded it etc). Very Happy
BTW if you go looking for an ABV find one for me too lol
STR8 2.8
Re: hard to start ma61 Sat, 23 August 2003 06:08 Go to previous message
oh, sorry zzt
Previous Topic:1983 Celica-Supra Foglights...
Next Topic:upgrading my rims...
Current Time: Thu Nov 19 12:18:28 UTC 2026
Total time taken to generate the page: 0.012004137039185 seconds
