Toymods » Tech & Conversions » TA22 Conversion
Lil Davo
Penrith
TA22 Conversion Thu, 21 August 2003 10:38 Go to next message
im looking at possibly getting a TA22 in the coming months as a sort of project car, as i dont want to touch the trueno as its my daily driver.
before picking one up though i thought id check out which conversion to go with and just wnated peoples opinions on this in terms of what the easiest, most practical and affordable transplant is? I was looking at a 3sgte? is tyhat a good or bad option?
Re: TA22 Conversion Thu, 21 August 2003 10:39 Go to previous messageGo to next message
3t-gte will be the easiest (i think?)
ra23celica1977
SYDNEY
Re: TA22 Conversion Thu, 21 August 2003 10:56 Go to previous messageGo to next message
3sgte is awesome but very costly
unless you can do the work yourself
Lil Davo
Penrith
Re: TA22 Conversion Thu, 21 August 2003 11:00 Go to previous messageGo to next message
some work would be done by myself id say..other stuff outsourced...what would be an estimate on the cost if i had it totally done by someone else?...that way i can work downwrads by doing bits and pieces myself Smile
Re: TA22 Conversion Thu, 21 August 2003 12:03 Go to previous messageGo to next message
3S-GTE done by someone else would cost about 12k Rolling Eyes
Lil Davo
Penrith
Re: TA22 Conversion Thu, 21 August 2003 12:14 Go to previous messageGo to next message
id say id be able to do some myself in order to cut down that cost though.....
what other popular conversions are there for the ta22?
roadrunner
Hornsby, Sydney
Re: TA22 Conversion Thu, 21 August 2003 12:40 Go to previous messageGo to next message
A 4AGE conversion isn't too hard as you can use the same gear box almost( just get one out of a sprinter) theyre fairly cheap now and is a desent amount of power
you could put in a 4AGZE or 20v if you wanted more power
Lil Davo
Penrith
Re: TA22 Conversion Thu, 21 August 2003 13:26 Go to previous messageGo to next message
if was to go for one of those 2 id take a gze....ive got the 20v and the moment and want more power than what vie got at the moment
thats why i was looking at the 3sgte Smile
DVS_ONE
Re: TA22 Conversion Fri, 22 August 2003 00:02 Go to previous messageGo to next message
Do the 13BT Very Happy Evil or Very Mad I DID!!!
Lil Davo
Penrith
Re: TA22 Conversion Fri, 22 August 2003 00:12 Go to previous messageGo to next message
yeah that would be sweet, but more costly than id imagine....how much did u do it for if you dont mind me asking?
Lil Davo
Penrith
Re: TA22 Conversion Fri, 22 August 2003 00:19 Go to previous messageGo to next message
draven wrote on Thu, 21 August 2003 20:39
im unfamiliar with the 3t-gte...what car are they sourced from?
moo4AGZETA22
Tasmania
Re: TA22 Conversion Fri, 22 August 2003 02:01 Go to previous messageGo to next message
I literally completed the install of the 4AGZE into my TA22 on Tuesday night Smile (wiring, exhaust, etc to go Crying or Very Sad). Anyone have the AW11 4AGZE wiring diagram?
It was not to hard, and my brother and myself managed everything except the cross-member mounts, which my uncle cut and re-angled. He is a welder which is handy.
The gearbox is NO problem, the engine sits a long way back (good for handling), and has clearance all round to replace pipes and hoses without taking the engine out. The heater hose out the back end was the only bit that required much thought. I used Sprinter engine mounts too.
Pulley, front mount intercooler, 2.5 inch exhaust = ~200HP.
SC 14, big cams, cam gears, head work = ~240HP
All this with the factory ECU. Easy way to save money.
A new BMW M3 has around 230HP per ton, a base model 911 has 240HP per ton.... TA22 weighs ~950 kg.....
That's my 2 cents worth.
Justin Rolling Eyes
DVS_ONE
Re: TA22 Conversion Fri, 22 August 2003 02:30 Go to previous messageGo to next message
Lil Davo wrote on Fri, 22 August 2003 10:12
Well jus for the conversion with larger cooler it was just over 9K but i didnt supply anything. i got engine series 5 13bt & gear box, cooler, Micro MTX 8 computer all wiring, Transmission tunnel Modified to fit gear box, tail sharft work, fuel system ect. But i still have to have a diff conversion and upgrade brakes Cool well worth the satisfaction when you are driving her Evil or Very Mad
DVS_ONE
Re: TA22 Conversion Fri, 22 August 2003 02:32 Go to previous messageGo to next message
moo4AGZETA22 wrote on Fri, 22 August 2003 12:01
Justin Rolling Eyes
Where did u get that figure for a TA22? My TA22 GT model is 1020Kg not 950kg..
Lil Davo
Penrith
Re: TA22 Conversion Fri, 22 August 2003 02:50 Go to previous messageGo to next message
DVS_ONE wrote on Fri, 22 August 2003 12:30
i cna imagine Smile and for the 9K the total conversion was done for you...that doesnt sound to bad at all...i imagine a bit of custom work hafd to be done?
DVS_ONE
Re: TA22 Conversion Fri, 22 August 2003 02:58 Go to previous messageGo to next message
yeah a little bit, the transmission tunnel would have been probably the biggest custom job and the mounting of the engine. im hoping to get her repsrayed same colour but with a white pearl but thats going to have to wait until i get all the other mods done Sad
alwaysRA23
Re: TA22 Conversion Fri, 22 August 2003 03:41 Go to previous message
4agte,
its not uncommon to pull over 150RwKw with one of those set up correctly...
Previous Topic:high compression VS rev-ability of Hi-Po 18RG
Next Topic:Vacuum lines on IG-GTE?
Current Time: Wed Oct 28 05:19:51 UTC 2026
Total time taken to generate the page: 0.12602114677429 seconds
