Toymods » Tech & Conversions » Using N/A cams on 7MGTE??
SUPRAGTE
North Sydney
icon5.gif  Using N/A cams on 7MGTE?? Wed, 10 July 2002 09:19 Go to next message
Anyone using N/A cams on 7MGTE??
grande91
Re: Using N/A cams on 7MGTE?? Wed, 10 July 2002 14:59 Go to previous messageGo to next message
Yep and you can FEEL the difference.
Allan
Re: Using N/A cams on 7MGTE?? Wed, 10 July 2002 22:53 Go to previous messageGo to next message
wonder whats better NA cams or 5/6m-g head?
i have NA cams ill swap for a hi-flowed CT26 Smile
Allan
jza70-mel
Perth WA
Re: Using N/A cams on 7MGTE?? Thu, 11 July 2002 12:25 Go to previous messageGo to next message
Can you feel the difference because there is actually more power, or that boost coming on becomes more pronounced?
grande91
Re: Using N/A cams on 7MGTE?? Thu, 11 July 2002 13:42 Go to previous messageGo to next message
no there's a few extra kw there.
Re: Using N/A cams on 7MGTE?? Sun, 14 July 2002 12:20 Go to previous messageGo to next message
Wouldn't putting a 5MGE/6MGE head on a 7MGTE basically turn it into a 6MGE with the 7M turbo stuff? ie. wouldn't you effectively end up with just a 6MGTE seeing as a 6MGE shares a 7M crank to make it 3l...?
kevz0r
Re: Using N/A cams on 7MGTE?? Tue, 16 July 2002 17:41 Go to previous messageGo to next message
when the 5M bottom end finally gives up i'll most likely be sticking a 7M bottom end down there
but dont see why to have a 7m head and go back to 12 valve head. trying to say something to do with how 6MGE makes better power than 7MGE?
Allan
Re: Using N/A cams on 7MGTE?? Wed, 17 July 2002 01:14 Go to previous messageGo to next message
2 valvles dont flow as good as one big one under boost apparently!
Allan
kevz0r
Re: Using N/A cams on 7MGTE?? Wed, 17 July 2002 01:48 Go to previous messageGo to next message
no, big valves can take heat better
Re: Using N/A cams on 7MGTE?? Wed, 17 July 2002 02:13 Go to previous messageGo to next message
Yeah...this is going to happen IF you can get the head off ey Kev? Razz
kevz0r
Re: Using N/A cams on 7MGTE?? Wed, 17 July 2002 02:39 Go to previous messageGo to next message
thats what angle grinders are for Rolling
[Updated on: Wed, 17 July 2002 03:04]
Allan
Re: Using N/A cams on 7MGTE?? Wed, 17 July 2002 07:46 Go to previous messageGo to next message
looking for a 7m-ge bottom end?? i may have one for sale if your interested let me know!
Allan
SUPRAGTE
North Sydney
Re: Using N/A cams on 7MGTE?? Wed, 17 July 2002 07:53 Go to previous messageGo to next message
Looks like i'll be going for some 7m NA cams soon then.
Yeah sure al i'll swap you my hi-flow T04E for some NA sticks!!!
Hehehehe me he he muuuha ha muuuuuuuhahahahahahaha Smile
i still set my alarm to go down in the middle of the night and make sure she's still bolted into the engine bay. Smile
So Grande91 does she still idle smoothly?
I dont want to loose the smoothnes.
Allan
Re: Using N/A cams on 7MGTE?? Wed, 17 July 2002 07:58 Go to previous messageGo to next message
SUPRAGTE wrote on Wed, 17 July 2002 5:53 PM
How about a whole 7M-GE head for the hi-flow and then you would have to just get a bigger turbo Smile
Allan
grande91
Re: Using N/A cams on 7MGTE?? Wed, 17 July 2002 14:03 Go to previous messageGo to next message
SUPRAGTE...you would'nt even know..when i took the GE head of the GTE block and put the original head on it i thought...what the f... happened to my engine,..loss of power you can tell right away....the guys at SOGI recomended it as well...cheers.
SUPRAGTE
North Sydney
Re: Using N/A cams on 7MGTE?? Thu, 18 July 2002 10:21 Go to previous messageGo to next message
I dunno al, my $2000(min) turbo isn't worth the swap for a 7MGE head just yet. Smile
So Grande is there any difference between the two heads or is it just the cams?
If not i might go through some wreckers and find a decent head and grind out the combustion chambers. Tony Rigolli showed me the other week how he was removing all the chunks of soft alluminium that shroud into the combustion chamber. Removing these soft edges that glow hot drops the compression ratio and reduces detonation occuring which blows these 7MGTE head gaskets.
His sons car is a Nissan GTS with a 7MGTE in it! I love it, 468 rear wheel hp with completely standard internals, had never been cracked open straight out of Japan.
grande91
Re: Using N/A cams on 7MGTE?? Thu, 18 July 2002 11:19 Go to previous messageGo to next message
no there's no dif at all, the difference is on one of the cam's, cant remember which,... i bought a N/A head from the wreckers not long ago for $300 complete, it even had the little plate on it, that tells you if it has been cooked at all,...i got it surfaced, cleaned up,and a minor port, and its on the shelf waiting for my hg to blow.... 468hp hey!,....thats Rigoli's, money money money, if we had the cash we could have done it but!!.... cheers.
SUPRAGTE
North Sydney
Re: Using N/A cams on 7MGTE?? Fri, 19 July 2002 08:54 Go to previous messageGo to next message
It was all in the turbo and exhaust manifold. I got some pics of it too! It is massive, if you want the pics i can email them too you, they are very fat!
Rolling
grande91
Re: Using N/A cams on 7MGTE?? Fri, 19 July 2002 12:58 Go to previous messageGo to next message
ok i would'nt mind having a look....thanks.
ed_ma61
Lost in the K hole
Re: Using N/A cams on 7MGTE?? Sat, 20 July 2002 14:34 Go to previous messageGo to next message
im pretty sure its only the intake cam thats different between the ge and gte.
ed
grande91
Re: Using N/A cams on 7MGTE?? Sat, 20 July 2002 15:40 Go to previous messageGo to next message
YEP thats the one intake, how F...... can i get, i've been working on the 7m's for over two years now and i could'nt remember which is which.
Allan
Re: Using N/A cams on 7MGTE?? Sun, 21 July 2002 04:53 Go to previous messageGo to next message
i have todo some research into cams turbo LPG bumpy sticks are an unknown!
Allan
Re: Using N/A cams on 7MGTE?? Sun, 21 July 2002 05:25 Go to previous message
Yes, me too. I need to try and learn me a little bit more about cams on small LPG turbo engines, wouldn't mind livening mine up a touch once I replace the turbo/cooler.
Previous Topic:New Tacho
Next Topic:Sprinter Diff
Current Time: Mon Oct 26 04:55:27 UTC 2026
Total time taken to generate the page: 0.086507081985474 seconds
