Toymods » Tech & Conversions » weird idle on warm up?
RA231G-GTE
melb eastern subs
weird idle on warm up? Fri, 22 August 2003 05:16 Go to next message
when i start my 1ggte on warm up it revs high and then it drops low and then it continues up and down up and down until the car is warm my engine is running rich could this be the problem.this engine is starting to do some weird sh#t.any help?
sleeka73
Re: weird idle on warm up? Fri, 22 August 2003 09:12 Go to previous messageGo to next message
that sounds like my 2t at the moment, i think it might be the mixture aswell
KiRK
Re: weird idle on warm up? Sun, 01 May 2005 06:51 Go to previous messageGo to next message
Did anyone find a solution to this problem? My 1g is doing the exact same thing. Ran perfeclty in the donor car, but upon transfer...
Kirk
frontspinner
Eastern Melbourne
January 2005
Re: weird idle on warm up? Mon, 02 May 2005 09:23 Go to previous messageGo to next message
weird! my 4AGE has done that a few times before!
i think mine does it when theres a problem in the cooling system, last time it did it i'd blown a heater hose, and it did it recently and id done the water pump gasket.
i dont know if this is the same problem but its worth a try.
have you tried disconnecting the batterie, then pushing the brake till all the power is gone then hook it all back up to reset the computer? i have heard this works for some problems like this.
HyDrA
Adelaide, SA
Re: weird idle on warm up? Mon, 02 May 2005 09:38 Go to previous messageGo to next message
ISCV is locked open imho.
Happened to me, fix it and it will all be ok (look at the power source!)
sideshow
Re: weird idle on warm up? Mon, 02 May 2005 12:03 Go to previous messageGo to next message
pull th eidle motors apart and clean em
i have found afew with seized bearings
u can spray wd40 in em and free em up
but it could also be bad coolant temp sensor
or air in cooling system sometimes
or it could be tps set wrong
all these affect the warm up of an engine
Jorrs
Coffs Harbour
Re: weird idle on warm up? Mon, 02 May 2005 14:44 Go to previous messageGo to next message
AFM,oxy sensor ?
frontspinner
Eastern Melbourne
January 2005
Re: weird idle on warm up? Wed, 04 May 2005 11:21 Go to previous message
Hey, just letting you know, i got a new water pump,( i suspected it was to blame) and the weird idle has gone! she runs perfectly now!
Previous Topic:1JZ auto, manual shifting
Next Topic:4agze s/c
Current Time: Sun Oct 25 08:05:20 UTC 2026
Total time taken to generate the page: 0.038470983505249 seconds
