Toymods » Tech & Conversions » URGENT HELP!!! 4AC timing belt woes :(
icon9.gif  URGENT HELP!!! 4AC timing belt woes :( Sat, 23 August 2003 07:00 Go to next message
Hiya Ppl,
i'm changing the timing belt on my mums 4AC, and have a few issues...
first up, the idler pulley that sets the belt tension. theres a bolt that goes thru the pulley and theres a hole the spring goes into, and there is another hole that is about 8-10mm, that looks like it's meant to pivot on something...
there is a hole in the alloy case behind it for a plug to go in, for the bracket to swing on, but no plug!!! is this normal for a 4AC?? can i just tighten the pulley in place to set the tension, or should i really have a bit sticking out of the alloy casing for the bracket to swing on.
secodn thing, the manual says to keep water and coolant off the timing belt. how clean does everything have to be?? do i need to fully degrease the covers and the pulleys? ie to ultra clean??
it's raining, and i have too much stuff to do Sad.. if anyone could give me advice on these issues, could you call me on 0410 677 857?? any advice greatly appreciated!!!!!!!!
thanks in advance!!!!!!!!
Re: URGENT HELP!!! 4AC timing belt woes :( Sat, 23 August 2003 08:00 Go to previous messageGo to next message
oh bugger. it looks like there is an exit wound on the bottom plastic cover where something, that is suspiciously the same size as the hole in the idler pulley bracket, has has decided to part with the engine... taking the belt out with it...
dagnabbit.......
IRA11Y
Club Member
Re: URGENT HELP!!! 4AC timing belt woes :( Sat, 23 August 2003 08:10 Go to previous messageGo to next message
you have mail Smile
Re: URGENT HELP!!! 4AC timing belt woes :( Sat, 23 August 2003 08:49 Go to previous messageGo to next message
Thanks heaps Michael!!
you're a legend!!! Very Happy
i looked aorund and found the gearbox dowels on k motor are same diameter.. not sure how the solid dowel will be going into the alloy on the 4A, but i'll be careful Wink... seal it in with loctite or epoxy or something.....
thanks again Very Happy Very Happy Very Happy
IRA11Y
Club Member
Re: URGENT HELP!!! 4AC timing belt woes :( Sat, 23 August 2003 23:46 Go to previous message
should be fine, the3y dont move its just the bracket that moves on it so if its steel it will wear better anyway
Previous Topic:Fuel filter for a 86 soarer
Next Topic:Nevo 175mm pulley fouling water pump pulley!!!
Current Time: Sun Oct 25 15:46:29 UTC 2026
Total time taken to generate the page: 0.0066370964050293 seconds
